Precision PS - 100% Radial Caps ?
Anyone used all radial caps in the precision power supply? What's the negative effect if any of using radial caps instead of the two larger axials at the first node?
TM
									TM
Life is deaf, knock loud!
Re: Precision PS - 100% Radial Caps ?
You are probably still going to need to use two in series with balancing resistors to get the voltage rating requirement down.  A quick look at the dimensions of 220uF, 300+ volt units shows that they are about 50mm (2") tall and 25mm (1") in diameter, so unless you have an unusually deep chassis you'll have to lay them down and then secure them to the board with silicone adhesive.  Other than that, I see no reason why you couldn't use them.
MPM
						MPM
- glasman
I have been using radials in that position for a couple of years. I think they sound pretty good. I think Andy Fuchs as uses radials in that position. These days I think the you have a better selection of caps in radial varieties than are available in axial, but that is OMO.ToneMerc wrote:Anyone used all radial caps in the precision power supply? What's the negative effect if any of using radial caps instead of the two larger axials at the first node?
TM
The picture below shows a Glaswerks using radials on the power supply board.
Gary
About 5 miles south of I-94
www.glaswerks.com
www.glaswerks.com
Nice compact all-in-one PS board!  First filter is 4x120uF (?) radials, with two paralleled pairs in series?
MPM
						MPM
- glasman
4x100uf. 350vmartin manning wrote:Nice compact all-in-one PS board! First filter is 4x120uF (?) radials, with two paralleled pairs in series?
MPM
www.glaswerks.com
www.glaswerks.com
I gave them a shot on a couple prototype transition amps making the switch over to PCB...To me it gave the amp a kind of sterile feel and stiffer/faster attack than the larger radials.... I tried 4 @ 100 350 on 3 prototypes...I don't personally care for them on the plates and screens but think they are fine for the preamp.. IMHO... Just to use to the bigger radials I guess..
Gary, are they Nichicons?glasman wrote:4x100uf. 350vmartin manning wrote:Nice compact all-in-one PS board! First filter is 4x120uF (?) radials, with two paralleled pairs in series?
MPM
- glasman
They are Xicon XRL series. I use Nichicons in a couple of other products.BobW wrote:Gary, are they Nichicons?glasman wrote:4x100uf. 350vmartin manning wrote:Nice compact all-in-one PS board! First filter is 4x120uF (?) radials, with two paralleled pairs in series?
MPM
Gary
www.glaswerks.com
www.glaswerks.com
Beautiful amp Gary. If you don't mind my asking, what values do you use for your balancing/bleeder resistors?glasman wrote:They are Xicon XRL series. I use Nichicons in a couple of other products.
Thanks.
- glasman
They are 270K in that amp. I use various values on what I am looking for in the amp.Structo wrote:Look like they may be 270K.
www.glaswerks.com
www.glaswerks.com
Thanks guys, radials it is then.
TM
						TM
Thanks Gary.glasman wrote:They are 270K in that amp. I use various values on what I am looking for in the amp.Structo wrote:Look like they may be 270K.
Gary,glasman wrote:They are 270K in that amp. I use various values on what I am looking for in the amp.
Can you describe the impact that the different bleeder values make in the amp?
Thanks,
Michael
Me: Just one more...
- glasman
The bleeders have an effect on the touch of the amp. The classic rule of thumb in power supply design is 1K resistance per volt of supply (ie 440K for a 440V supply). Going smaller helps to regulate the supply a bit better and makes it tighter and going larger (say 470K for each balancing resistor) will loosen up the supply regulation and add some squish to the touch of the amp.mlp-mx6 wrote:Gary,glasman wrote:They are 270K in that amp. I use various values on what I am looking for in the amp.
Thanks,
Michael
Let your ears decide.
Gary
www.glaswerks.com
www.glaswerks.com
