Moderators: pompeiisneaks , Colossal
steve_p
Posts: 206 Joined: Tue Jun 14, 2011 12:03 am
Post
by steve_p » Thu Jan 10, 2013 6:58 pm
ic-racer wrote: steve_p wrote: What value presence put are you using? If it is 2k, i have a few clarostats with short shafts if you want one.
Steve
Thanks for the offer. Last night my long shaft 2k had an appointment with the hack saw...
I also cut the bias pot short and slotted it with the hack saw.
Love the hacksaw...almost as much as the Sawzall...
Build looks great so far!
LeeMo
Posts: 371 Joined: Mon Feb 13, 2006 2:37 am
Post
by LeeMo » Thu Jan 10, 2013 7:31 pm
I use one of these to trim long shafts to size.
LeeMo
Posts: 14036 Joined: Wed Jan 16, 2008 2:19 am
Post
by M Fowler » Thu Jan 10, 2013 7:37 pm
Are you going to want to install bear claw tube retainers before you get further along?
Chad
Posts: 297 Joined: Thu Jul 21, 2005 3:31 pm
Post
by Chad » Thu Jan 10, 2013 7:42 pm
LeeMo wrote: I use one of these to trim long shafts to size.
LeeMo
Same here. I had a couple of them laying around one day and decided too use one and have used it every sense. Chad
ic-racer
Posts: 1318 Joined: Tue Dec 18, 2007 2:24 pm
Post
by ic-racer » Thu Jan 10, 2013 8:19 pm
M Fowler wrote: Are you going to want to install bear claw tube retainers before you get further along?
Actually the bear claws are on the way with the 9 pin sockets and a set of JJ tubes from Antique Radio Supply. Putting the bear claws in will be easy because I used PEM nuts on the chassis.
Post
by M Fowler » Thu Jan 10, 2013 8:25 pm
Oh that was a great idea using pem nuts.
ic-racer
Post
by ic-racer » Fri Jan 11, 2013 5:51 pm
I got the AC/Standby/Ground switches. Wow, it is a close fit.
Posts: 3271 Joined: Sat Jan 15, 2005 8:10 am
Post
by Mark » Fri Jan 11, 2013 10:14 pm
How close?
Remember this is ac voltage which can arc. Heat shrink might be in order given you are talking about a dangerous part of the circuit.
Yours Sincerely
Mark Abbott
ic-racer
Post
by ic-racer » Fri Jan 11, 2013 11:07 pm
Mark wrote: How close?
Actually it is the switch bodies that are close. I laid out the holes based on my scaled drawing which is based on the picture. The switch bodies almost touch but I think it will be OK.
ic-racer
Post
by ic-racer » Sun Jan 13, 2013 7:44 am
Post
by Mark » Sun Jan 13, 2013 9:16 am
That middle switch is scary.You may need an insulated connector or a few layers of heat shrink.
Yours Sincerely
Mark Abbott
ic-racer
Post
by ic-racer » Mon Jan 14, 2013 10:32 pm
Mark wrote: That middle switch is scary.You may need an insulated connector or a few layers of heat shrink.
Yes that switch is going to get reworked. It is supposed to have just two solder eyelets, instead of 4 spade connectors.
Post
by Mark » Tue Jan 15, 2013 9:00 am
Keep plodding Ice you're doing great work, I can't wait for the You Tube clips, you'll have to do a side by side comparison with a Bassman, a reissue will do.
Yours Sincerely
Mark Abbott
Posts: 15446 Joined: Wed Oct 17, 2007 1:01 am
Post
by Structo » Tue Jan 15, 2013 1:56 pm
Why not use a switch like a Carling, like the one on the left?
