new build is now happy
Re: new build is now happy
So the problem was a bad bias pot?
Not a problem, the next step was that I was going to call you. It all worked out, besides you learn much more when things don't go as planned.
TM
TM
dcribbs1412
Main problem was my poor workmanship in that I hadSo the problem was a bad bias pot?
a filament wire shorting out... after that it was the bias pot
not sure if the pot was bad to begin with or a short killed it
Thanks TMNot a problem, the next step was that I was going to call you. It all worked out, besides you learn much more when things don't go as planned.
really cool to know guys like you(heisthl,and Tony and others) are there for us newbies, without which I for one would be SOL
I am still learning to build and building to learn
Darin
I am glad for you Darin, congratulations!
"I am still learning to build and building to learn"
A lot of us are. But get ready, time will come when you will be helping others!
Cheers!
Cheers!
Horacio
Play in tune and B#!
dcribbs1412
Thanks alvarezh
I hope I can help someone out with a build someday
just seems like the more I learn the more I see I need to learn
if that makes sense.
Also I appreciate your time on this build
Thanks again
Darin
Thanks again
Darin
Darin,
Have you played through the amp for tone report.
dcribbs1412
Hi Mark
Sunday is "quiet day" or so my wife says(new rule...
I did plug in and I can tell its working fine
I will crank it ASAP and report back
Darin
Darin
dcribbs1412
Had a few minutes to crank it
family was out of the house...
JJ 6ac7 power tubes
Using a LP with 57 Classics
A ToneTubby Alnico as test speaker in open back cab
no dlator or effects
My initial reaction was it was brighter than I was expecting
easier to get a good balance between OD and Clean using
both pickups and Volume knobs
It defiantly has an attitude..nice to have the power to be pissed or subtle just using the guitar controls
Will be trying different tubes and checking voltages next.
Strat and Tele is waiting as is EV speaker.
Will need to research some PAB options it seems a little anemic
My first 100 watt build...not my last
Really appreciate everyones help on this build
Darin
JJ 6ac7 power tubes
Darin
My #183 has just a little glass on it, not harsh or anything though. When I hook up the D'Lator and the RG400 patch cables, it makes world of difference.dcribbs1412 wrote:
Darin
How did you wire the PAB relay/R-J switch using Jason's relay board?
dcribbs1412
Hi ToneMercMy #183 has just a little glass on it, not harsh or anything though. When I hook up the D'Lator and the RG400 patch cables, it makes world of difference.
just a little glass on it...
I don't feel any harshness with this build either
as for the PAB I pretty much followed the layout...would be fine ifHow did you wire the PAB relay/R-J switch using Jason's relay board?
that's wrong because it doesn't sound quite right...Now that I think of it remember someone saying to use an on-off-on switch for that...which I did not...I have to ask TM how is it wired?
Darin
Glad you got it going Darin.
Just a heads up, the OD trimmer can really make or break the OD sound.
Most recommend a setting of 20-30K.
That is measured at the wiper to ground with the amp on and the OD switch on.
I like mine around 25K.
dcribbs1412
Thanks Tom
I haven't spent a lot of time with it
but I have it set around 22k now and it seems good
I did change drop string from 22k to 18k and upped the voltage on V1 from
around 195 to 205 and still playing with preamp tubes
Problem now is the FET input isn't working
so I'm looking closer at my wiring of that.
Darin
Darin
Darin,
I've found that those switches on the fet input jack can be touchy. they have to make good contact.
dcribbs1412
Good to know CHIP
I'll check it out
I ordered some Kobiconn jacks
if all fails I'll try one
Darin
I'll check it out
Darin
Yeah I used a Switchcraft 14b jack on my FET input and everything worked perfectly.
Then a month or so later I wanted to try my SSS strat guitar through it.
But it was cutting out, if I wiggled the plug it would work but then cut out.
I haven't pulled the chassis but I suspect those leaf switches need to be tweaked.
