10thTx wrote:It was pointed out that "Mat's 86 Special layout" and the "86 Special Duet layout" had an error on how the plate cap was hooked up on the EF86.
I corrected both layouts in this thread. However, please compare the schematics with the layouts of each and CHECK for ERRORS!
With respect, 10thtx
Thanks 10thtx, I have just put together the parts for this build, so it is much appreciated
Hey guys, loved mat's clip. that sound is awesome. I've been wanting to build something with an EF86 for quite some time. I think that is just the coolest tube.
edited...re read through the thread. I will use the 86 special schematic and layout. should be good enough. Does anyone have any guts they want to post?
Comments on the complexitiy of this build? This will be my second. I'm pretty sure I can handle it, but wanted to know degree of difficulty so i know what to prepare for. (how long to tell my wife how many weeks on end i will be in the basement workshop for)
Last edited by amplifiednation on Fri Mar 18, 2011 12:24 pm, edited 1 time in total.
SICK tone....the Dumble/Marshall vibe is definately there... Great clarity on the higher notes and the harmonics are nice and exaggerated with the delay.
Hey Mat, can you tell me if the voltages are similar to the ones on the schematic drawn by Colossal for the miniHRM? Has there been any mods or tweaks? Is the power supply still the same?
NEjoe wrote:Hey Mat, can you tell me if the voltages are similar to the ones on the schematic drawn by Colossal for the miniHRM? Has there been any mods or tweaks? Is the power supply still the same?
The reason I ask is that on the new 86 special schematic there is a 325V over the C in the power supply section.......
NEjoe,
thanks for bringing up Colossal's schemo, I had a look at it and saw that I hadn't included the parts for the HRM board...
I will go over that properly tomorrow and update my BOM, thanks and keep up the "eyes on" please
If you see anything that needs updating in the Mini HRM schematic, let me know.
Thanks. Great job on the 86 Special, another excellent sounding amp.
Hi Colossal, my miniHRM amp is now 86-Special so no updates for the miniHRM.
I strongly suggest to build the 86-Special (with Eminence Delta Pro 12A speaker) instead of the miniHRM. The 86 is the most enjoyable amp that I have played. Not a dumble style but more rock and roll amp. Much more easier to play than dumble style amps IMO.
I played the 86 today at the band rehearsals with my nonHRM. Both amps on simultaneously. Very interesting sounds
