M Fowler wrote:No you need to adjust the bias resistor which is the resistor infront of the inverted diode.
Depends on the bias circuit some are 470R to 2k2 or so.
I understand...the bias circuit( bridge I think) I'm using I do not have a resistor in that spot.I'm using similar to this 100uf/100v and a 15k
I tried a few different values in the 15k spot but none seemed to give me any different adjustment...
Darin
Hi Darin, so that yellow lead in your pic goes to the top of a pot, and the bottom of the pot goes through a 22k to ground, and the bias voltage is from the wiper? If so that is the most negative voltage you can get from that winding, and a bigger resistor to ground won't help.
martin manning wrote:Hi Darin, so that yellow lead in your pic goes to the top of a pot, and the bottom of the pot goes through a 22k to ground, and the bias voltage is from the wiper? If so that is the most negative voltage you can get from that winding, and a bigger resistor to ground won't help.
Martin, I was thinking along the same lines that it's most likely maxed out on that 15V tap. I'm still not clear as to why the HT winding bias scheme didn't work.
TM, I see no reason the HT tap w/ FWB didn't work either... lots of Marshalls out there with that set-up. Here's another look, Darin. The top of R31 is the bias voltage; right-hand side of C15 goes to one side of the the HT, before the main rectifier bridge.
TM
Thanks guy's
I have tried a few different values and nothing seems to make a difference
so I believe you guys are right...maxed out the 15V tap.
As far as the HV bias tap...I may take another shot at it, but
if you guys think its OK(safe) to run it with the 15V tap I may call it and move on...I got frustrated trying to figure out the HV tap...it seemed so simple.
