Congrats! Thanks for sharing the build.amplifiednation wrote:Thanks guys! The amp fired right up when I changed the relay wiring. It is working perfectly. It already sounds pretty good. I'll bias it and fiddle around with some of the trim pots.
thanks to everyone for their help!!
oh, and this has to be the quietest amp i have!! and also the loudest
#102 Started. Checking in
Re: #102 Started. Checking in
Deric®
Yeah, I believe that is my drawing for the relay.
I made those after getting the JBorders relay boards because they differ from the Dumble layout.
Here is the complete drawing showing the comparison of the two styles.
Martin's drawing just swaps sides of the relay so it is essentially the same.
Taylor
Glad you got it working Enjoy!!
T
T
amplifiednation
Tony thanks for the awesome layout. Next I'm going second gen after your good reviews. I already have some killer old iron for it!talbany wrote:Taylor
T
Amplified Nation
www.amplifiednation.com
@ampnation
@ampnation
amplifiednation
Got about 20hrs of burn on the amp. The bias drifted a bit. Have it biased at 13w/tube. Did 4hrs on then 4hrs off for about 40hrs with some cheapo Chinese tubes. Even the hiss seemed to mellow out. Used a 4ohm car speaker as a load. I think it was a good move.
Voltages
V1a/b-206/213
V2a/b-200/206
Pi-289/287 still playing with the trimmer. I have a nice amperex that seems matched
6l6- plates 445
Should I try to get v1 down a bit?or leave it as is for awhile?
Voltages
V1a/b-206/213
V2a/b-200/206
6l6- plates 445
Last edited by amplifiednation on Thu Nov 24, 2011 10:52 pm, edited 1 time in total.
Amplified Nation
@ampnation
@ampnation
Bring V1 down
Also your bias is way low, 13W a tube. That's around 45% dissipation. You want more 60-70%.
amplifiednation
I must have read some incorrect info about the 6L6. Rebiased to 19.5 at 65% . The amp is still singingChrisM wrote:Bring V1 down
I need to adjust b5 dropping resistor?
Amplified Nation
@ampnation
@ampnation
6L6GC are rated at 30W max plate dissipation, so that sounds better.amplifiednation wrote:I must have read some incorrect info about the 6L6. Rebiased to 19.5 at 65% . The amp is still singingChrisM wrote:Bring V1 down
Sounds like the right resistor to tweak. Also try swapping some tubes in there.
amplifiednation
Cool. I will try to figure out the right value to put in there. What are the effects of having V1 below V2? -10V is the goal??
Amplified Nation
@ampnation
@ampnation
amplifiednation
Voltages V1a/b-206/213
V2a/b-200/206
pi-289/287 still playing with the trimmer. I have a nice amperex that seems matched
6l6- plates 445
Amplified Nation
@ampnation
@ampnation
Taylor, these appear to be the same voltages that you posted when the amp was at 45%. The voltages shouldn't be exactly the same after rebiasing from 45 to 65%.amplifiednation wrote:ToneMerc wrote:What are the preamp voltages now?amplifiednation wrote:
V2a/b-200/206
6l6- plates 445
TM
amplifiednation
TM sorry here are current:ToneMerc wrote:Taylor, these appear to be the same voltages that you posted when the amp was at 45%. The voltages shouldn't be exactly the same after rebiasing from 45 to 65%.amplifiednation wrote:ToneMerc wrote: What are the preamp voltages now?
V2a/b-200/206
6l6- plates 445
TM
V1a/b- 208.4/215.7
V2a/b-203/208.2
PI 292.9/291.2
Thoughts?
Amplified Nation
@ampnation
@ampnation
The FET circuit is definitely connected to B5 right? Have you tried a different tube in V1? You could sub in a 4.7K in place of the 2.2K.amplifiednation wrote:TM sorry here are current:ToneMerc wrote:Taylor, these appear to be the same voltages that you posted when the amp was at 45%. The voltages shouldn't be exactly the same after rebiasing from 45 to 65%.amplifiednation wrote:
V2a/b-200/206
6l6- plates 445
TM
V1a/b- 208.4/215.7
V2a/b-203/208.2
PI 292.9/291.2
Thoughts?
TM
amplifiednation
Yes I have tried a couple different tubes. The FET is connected to B5. I wasn't thinking there would be current draw from there. I don't have the board wired right, I may have mixed up two resistors, which might explain the voltages at the tube. The FET input is not working right, it makes sound but sounds like its starving for dc. I will take a better look at the source resistor. I'm gonna get that working right before messing with the dropping string
Amplified Nation
@ampnation
@ampnation
