#102 Build started
Re: #102 Build started
If you are running 12V relay supply, that relay should work.
For the FET input jack, Switchcraft type 13E .
2N4416A is an equivalent JFET.
some progress has been made:
2:
3:
4:
will this jack be good for a FET input ?
some more work done today, will probably close shop for the next 2 weeks till i have some more time.
2:
3:
Angelus; Nice pics of your progess. One detail thing: I don't know what you used to draw the wire layout on the signal board, make sure you wipe it out. Some materials(like pencils) have conductive characteristics.
thanks for the advice, i will check continuity with my meter
almost finished with the pre-amp
2:
