new build is now happy
talbany
Re: new build is now happy
Post by talbany »
Darin
With the tubes out and limiter in check to make sure your neg bias voltage on the grids (pin 5) is stable w/decent range
BTW..W/limiter in is the amp getting the proper line voltage?...Your voltages look low..
dcribbs1412
Post by dcribbs1412 »
I don't think its working
voltage on pin 5 is not stable
120V at wall
power tubes out
re post of voltages B+ 3..455V B+4..335V B+5..327
V1..198,205 V2..206,219 V3 312,304
these readings look closer
talbany
Post by talbany »
Now pull the limiter and no tubes.. Is it still unstable?..
dcribbs1412
Tony last voltages where no limiter...
I have 3.3v on both filaments
I am measuring the wiper of the bias pot DC to ground right? for neg voltage
talbany
Post by talbany »
Yep!!...You should have a stable range around -20 to -60 for a pair of 6L's.. Go over your bias supply again make sure all your grounds are tight.. You can also disconnect your bias supply feeding the pot and make sure that's a stable point first..If it is you know it's either the pot or the grid feeders..Also check to make sure nothing is touching pin 5 on each tube and everything is wired correctly.. Probably something simple..
Good Luck
talbany
Post by talbany »
Darin
Looking over your bias supply.. Why do you have a 2 wires attached to the wiper (purple and white).. If the white is the supply coming off the board it should go to the bottom of the pot (not the wiper) and the purple to the 220K grid feeders or am I seeing things.. If your white wire is the bias feed your tubes will stay in cutoff..
dcribbs1412
I going by the 183 bias layout
which has bias 1 (yellow) and 2 (white) from the board and the purple
to the 220ks
is that right or am I not seeing things right
Darin
talbany
Post by talbany »
Darin
Ahhh OK.. I have never set up my bias supply like 183 so I can't tell you what's going on there.. I did notice though that your bias caps look backwards (as opposed to the 183 layout) or am I not seeing this right..
dcribbs1412
Could be Tony I assumed the black lines where neg side
dcribbs1412
Thanks Mark
that's the one I am referencing
talbany
Post by talbany »
Cool OK..The black lines looked like the dimples..Also one other thing I see is it looks to me like the ground plane that runs along the bottom of the board where you have ground wire looks to be on the same plane as the white wire that feeds the wiper..Is that bias board PCB the same as what's in the 183 layout or am I missing something..
heisthl
Post by heisthl »
dcribbs1412 wrote:Tony
just so I'm sure what your asking
I have the meter on DC black lead in black bias jack
and red in red jack...I get 0 mv when I sweep the bias pot no tubes in
I hope this is right...
That's normal - there could be no current flow through the 1 ohm with no tubes in. Is there negative voltage on the wiper of the bias pot?, on the grid resistors of the output tubes?
www.RedPlateAmps.com
dcribbs1412
I'm pretty sure it is
no sir no voltage
Darin
talbany
Post by talbany »
That's really strange I can clearly see 2 etches that run to that white wire and your board posted only shows 1.. Anyone else see this or is it just me.. :?
