Check this out......
Charlie Wilson
Re: Check this out......
Post by Charlie Wilson »
Redshark, you are the man! Lowplate Classic?
CW
redshark
Post by redshark »
I have many more pictures coming. I just have to transfer from my phone to my laptop. :)
Whoever wants to build me a clone of this amp is welcome!! It sounds awesome!! I will try to upload a video of how it sounds. the problem is that I will use my phone so no great sound quality but anyway it will be a reference.
redshark
Post by redshark »
I'm a trainwreck guy!! I have no clue of Dumble terms but, plate voltage is 460vdc. :)
glasman
Post by glasman »
Aaron wrote:Thanks Redshark :D
Very interesting layout. The question is, why did HAD decide to do a completely different layout and circuit board for this amp?
And, how many more PCB amps are there?
Thanks again,
Aaron
I have pictures of one that has a blue PCB, if I can find it I will post it, I have never seen one in this tube configuration, I will have to stare at the pictures a while to see what he gained from the layout.
About 5 miles south of I-94
www.glaswerks.com
glasman
Post by glasman »
FuzzFaceBuilder wrote:Dang! I've always wondered the chassis layout for PCB ODS amps. Between this and the Rick Vito ODSR we've got two great examples! Thanks again Redshark!
Ok, am I blind? where are the relay boards?
I know I am getting old....
www.glaswerks.com
FuzzFaceBuilder
Post by FuzzFaceBuilder »
The second pot on the PI board, an NFB trimpot?
FuzzFaceBuilder
Looks like there's a relay in the corner of V2 PCB.
redshark
Post by redshark »
The chassis after the recap....
Aaron
Post by Aaron »
On the overdrive board.
redshark
Post by redshark »
Right next to something that looks like a trimmer. That is siliconed. Probably Howard tuned it to Hoyt's liking and glued it. I have to start studying this amps. I have been here since 2009 dedicated to trainwrecks. I rarely read about Dumbles.
Aaron
Post by Aaron »
Thanks again,
Aaron
Is that the blue suede head? That had a different PCB layout again.
That is one of my favourite looking amps, blue suede with vox cloth.
Aaron
lovetone
Post by lovetone »
Hers an idea if you get chance,
Solder a white LED on long leads, power it from a 9v battery through a 2.2k resistor.
Place the led under the pcb and turn the light s down, you can now see the traces under the pcd if you can get a good picture of these we can see the traces and draw up the schematic :D
I do this some times on pcb amps when fault finding with now schematic
lovetone
Post by lovetone »
I wonder if this method was an attempt to make the amp into modules to ease production and reduce construction time?
glasman
Post by glasman »
Yeah I spotted that after I posted the comment. I don't see a PAB really, maybe he dumped it from the design.
www.glaswerks.com
glasman
Post by glasman »
Thanks again,
Aaron
Aaron
Yes that is the one.
It looks like a straight build of his standard board onto a PCB.
www.glaswerks.com
