D Deluxe
Charlie Wilson
Re: D Deluxe
Post by Charlie Wilson »
Steve, I guess I was the one who recommended the Mercury Magnetics. Sorry about your experience with that. If you didn't clip the leads you can send them back. I used a Magnetic Components transformer before the Mercury and it failed. Thinking back, I may have chose to lower the B+ to soften the high end a little. I bet your #1 sounds as good or better than the original so don't settle for anything less.
CW
67plexi
Re: D Deluxe
Post by 67plexi »
Thank you Charlie #1 is the amp period. I used a Heyboer PT on the first build. I'm going to run them in stereo at practice today.
Check out the Fender section 5G12 Concert "AMP" that amp sounds
smooth as silk due to the Tweed Bassman #45249 OPT 5/1960
So #1 and the Concert amp when restored will be my gig rig.
Just playing #1 will take a year to remove the grin on my face
I'm happy #2 is a dud I know what direction to go with it you see I have
one more 1959 OPT 4/8 ohm taps. #2 will be a harmonic generator soon
And if it was that easy everyone would have one not so.
Steve.
67plexi
Re: D Deluxe
Post by 67plexi »
I played the #1 & #2 together they complement each other so I decided to fine tune the #2
With a GZ34 Voltage was to high so dropping string time B+2 to B+3 8k2 360VDC
B+3 to B+4 22k 310VDC. It did get rid of the harsh high end does is sing like #1 not at all
It has a nice chime clean tone that is useable. I get to play them live tonight see how they work together now.
Steve.
:D
67plexi
Re: D Deluxe
Post by 67plexi »
I'm not sure how to gage the new amps. My sound man was smiling all night Keith has run sound for me 30 years and the spectrum analyzer was maxed out the only other amp that has had a screen shot close is my ODS version of Mega-plx . Great audience response made more in tips than both amps cost to build. Winning combination. They passed the 4 hour flame test dead silent no hum or hiss.
Last part the management. I asked them if I was too loud they said turn it up I had a great night.
Thanks' to all. Steve.
:D
Re: D Deluxe
67plexi wrote:I'm not sure how to gage the new amps...
Really? How about off the chart? ;^)
CHIP
Re: D Deluxe
Post by CHIP »
Steve, I hear ya.
IMO, This circuit just seems to cover all guitar frequencies so pleasingly well.
Synchu
Re: D Deluxe
Post by Synchu »
Did someone mentioned cliips please? :)
On another thought - I have my 5E3 opened at the bench for installing VVR. May end up with something more..
Niki
lord preset
Re: D Deluxe
Post by lord preset »
Synchu wrote:Did someone mentioned cliips please? :)
Niki
Actually some begging has been going on. It's getting unseemly :wink:
JazzGuitarGimp
Re: D Deluxe
Post by JazzGuitarGimp »
Add me to the beggar's banquet - I'd love to hear that amp!
vibratoking
Re: D Deluxe
Post by vibratoking »
Don't post any clips...that amp could never live up to the hype. :P
drew
Re: D Deluxe
Post by drew »
Just to clarify:
PT
67plexi wrote:#1 has a 384-0-384 PT.
67plexi wrote:Thank you Charlie #1 is the amp period. I used a Heyboer PT on the first build.
Did you have this made, or buy it from a third party? Is there a Heyboer part number for it?
OT
67plexi wrote:This one has a 4/8 ohm tap.
67plexi wrote:And many thanks' to Robert Hinson for the 5/59 OPT.
67plexi wrote: #1 has a NOS 5/1959 OPT 4/8 ohm taps.
What make/model amp was this tranny made for?
Thanks.
67plexi
Re: D Deluxe
Post by 67plexi »
This is the NOS 1959 OPT that is going in #2
What model not sure it's for x2 6V6 4/8 ohm taps.
606-947 and K-58459 All I know it was from a Fender warehouse
I got the last three two for me and one for Eric.
As far as PT #1 used a mojo756EX Tweed deluxe I suspect that the secondary's have been lowered no way is it a 384-0-384
I have 399 VDC from pin 8 on the GZ34.
The Mercury Magnetics PT 380-0-380 has 427 VDC off of pin 8 GZ34
that's to high for NOS 6V6 350 volts max. I ordered a 330-0-330
to replace the Mercury Magnetics PT. I did try to make it work pin 8 5Y3
20 watt 500R to the primary B+ MM OPT 338 VDC then B+1 to B+2 8k2
and B+2 to B+3 22k that got my voltages close still sounds marginal. Look at the tube data on the JJ/6V6-S
Re: D Deluxe
Mojo 756EX is listed at 330-0-330 at 75mA. MC has 40-18078, 330-0-330 at 100 mA, whereas their 5E3 clone is 355-0-355 at 100 mA, both with 120VAC on the primary. So, the clone running on 110VAC (1950's line voltage) would produce 330-0-330.
67plexi
Re: D Deluxe
Post by 67plexi »
Martin that must be it but this is where the confusion is in play.
http://www.mojotone.com/transformers/Fe ... O756EX.pdf
http://www.mojotone.com/transformers/Fe ... ltage).pdf
The first transformer is listed as a 756EX
The second transformer is listed as a 756EXsp
No markings on the box or transformer I got it from TubeDepot
https://www.tubedepot.com/products/twee ... ransformer
I have a 330-0-330 on the way.
Re: D Deluxe
Well, this would not be the first time that Mojo's documentation has been found lacking. It will be very interesting to see if the lower voltage is the key.
