Dumble Overdrive Special to be reviewed in Premier Guitar
markusw
Re: Dumble Overdrive Special to be reviewed in Premier Guitar
Post by markusw »
ToneMerc wrote:
markusw wrote:
ToneMerc wrote: It's a clamp type of tube retainer used in missiles and aircraft
TM
Any idea where to get them?
Regards,
Markus
At one time I had a few left over from a shuttered rework facility. I'll see if I can get a part number.
TM
Great! Thanks a lot! :)
Regards,
Markus
Aaron
Post by Aaron »
talbany wrote:Yep..Looks like an all original untouched low plate classic. 8)
Things of interest are
1 Output and power transformer leads are spliced..Could have been seasoned iron used
2 3 part chassis w/wood sides
3 40uf on V1 and V2 (like 102)
4 The presence cap looks to be a bit smaller than a .1 (could be a lower voltage)
5 250K B (linear) Bass pot
6 Looks like 8k1 grid resistors? :? (usually 1k5 for a 6L amp)
7 Have not seen Dumble use those type screen resistors before?(that era)..Could have been replaced..Other than that pretty much just like the one documented here
https://tubeamparchive.com/download/file.php?id=14346
I'll bet this thing will talk to your daughter. :D
Nice amp indeed..Thanks for all the great shots Bryan and good luck with the article and sale of the amp..
All The Best!!
Does anyone know how many or what era the 3 piece/wooden sides are?
Does that mean #183 sat around for a few years in Dumbles shed or did he make these throughout?
Aaron
Max
Post by Max »
Aaron wrote:Does anyone know how many or what era the 3 piece/wooden sides are?
AFAIR starting with late 4th generation ODS amps with still the typical 4th generation "Dumble" logo on the back - #133 is the earliest serial number of these I know of (up to now) with such a kind of chassis. AFAIR Alexander Dumble continued using this kind of chassis for the "transition generation between 4th and 5th" amps with the gold script logo on front and most serial numbers in the 14X range and continued using these for the 5th generation ODS amps - but no longer for the 6th generation ODS amps.
BTW: AFAIR this kind of tube retainers (power tubes) you see on the pictures of #133 are rather typical for the first ODS amps with this kind of chassis - like those in the #14X range e. g.
talbany
Post by talbany »
Max
Good to see you here!!
Any idea on when Dumble stopped using the Tandy coax.. Was it somewhere in the transition 4th-5th gen amps..Also was it the 5th gen amps where Dumble used several types including the use of data cables etc..Can you elaborate further..
Have a great Day!
Max
Post by Max »
talbany wrote:Any idea on when Dumble stopped using the Tandy coax.. Was it somewhere in the transition 4th-5th gen amps..
AFAIR: Yes. E. g.: You can see the white coax cables for the reverb tank on one of the pictures of the back of #137 here: http://www.roblivesey.com/dumble/
talbany wrote:Also was it the 5th gen amps where Dumble used several types including the use of data cables etc..Can you elaborate further..
AFAIR most of the coax cables used by Alexander Dumble aren't typical cables for the transmission of audio frequencies as used for hifi sound systems e. g.. According to the layout in the "Dumble Files" section already the 2nd generation Columbia Flexfoam is a 93 Ohm coax cable and AFAIR not specified for the transmission of audio frequencies. And AFAIK Tandy RG59 75 Ohm has been used for the transmission of video frequencies. And AFAIR the different versions of these white teflon coax cables aren't specified for the transmission of audio frequencies either, but have been used as control cables etc.. I remember having seen 150W Dumble amps built in the second half of the eighties with up to four different versions of these white coax cables in one amp: Some thin and stiff (perhaps solid core?), some thicker and less stiff (stranded core), some with yellow stripes in the white etc.. Capacitance sometimes rather high BTW - AFAIR.
talbany
Post by talbany »
Thanks Max
Have been experimenting around with some different cables lately ..This should help!!
Have A Great weekend!!
bryanclark
Post by bryanclark »
episode is out:
http://www.premierguitar.com/Magazine/I ... 4#comments
I can't say it's the best. but then again we didn't have control over recording/editing/et al..
Hope you all enjoy it regardless.
Bryan
Bryan
bluesfendermanblues
Post by bluesfendermanblues »
Hi Bryan,
Excellent video.
You really got the epitome of what Dumble amps are all about.
BTW sounds very similar to my own Low plate classic clone.
Thank you!
exocet
Post by exocet »
Hi Bryan
Thanks for the video link, appreciate it a lot.
One thing jumped out to me - the clips that are titled "clean" sound anything but clean to me - especially the Humbucker Guitars used before you got to the Strat? The title then changes to Overdrive Switch - can clearly here the OD on that - but as I say, the clean channel sounds nice and "edgy" to me. I've found my High Plate Skyliner to be "pristine clean" ...too clean for my tastes, without the OD engaged. Just wondering where the "dirt" is coming from?
bryanclark
Hi everyone,
just wanted to let you all know - The Dumble OS ser#133 is now FOR SALE! And I will have it this weekend for the Nashville Amp Show. anyone interested please reach out! cheers, Bryan
Bryan
FUCHSAUDIO
Post by FUCHSAUDIO »
Not sure if you are the Owner/seller, but there are some details in the e-bay listing that are not correct. I'm at the show, hope we can hook up !
