Power Supply/ New Build #183 clone
butwhatif
Re: Power Supply/ New Build #183 clone
Post by butwhatif »
Where did you get the chassis?
CHIP
Post by CHIP »
grtamp wrote:great work , what type of the resistor you use in PI stage , katode , OD input? (blue resistor) are KOA SPEER ? MF or CF ?
those are NTE 1/2 w. metal film. The 2 brownish red caps are NTE.
Used according to 183 layout.
CHIP
Post by CHIP »
butwhatif wrote:Where did you get the chassis?
that's a CE chassis. Very nice chassis indeed.
stelligan
Post by stelligan »
Dunno how I missed this one. Damn stellar looking build! Congrats.
CHIP
Post by CHIP »
Thanks Stelligan, I always enjoy your clips.
CHIP
Post by CHIP »
After playing the amp for awhile now I'm finding something strange with the rock/jazz switch. When I put the switch in the jazz position, it is actually just going into PAB. I get the same result with the switch in the "rock" position and the PAB engaged on the foot pedal.. I followed the #183 layout wiring.
I don't know if the layout is incorrect or what.
has any other #183 builders noticed this?
ToneMerc
Post by ToneMerc »
CHIP wrote:After playing the amp for awhile now I'm finding something strange with the rock/jazz switch. When I put the switch in the jazz position, it is actually just going into PAB. I get the same result with the switch in the "rock" position and the PAB engaged on the foot pedal.. I followed the #183 layout wiring.
What type of switch did you use? On-On, On-off-On or On-On-On?
CHIP
Post by CHIP »
I used an On On. I thought that was what it was supposed to be.
David Root
Post by David Root »
It does look good! Thanx for sharing.
I have Jason's PS boards too, AND I have a pair of those exact Nichicon 330uF/400V/105 deg C caps. Do you find the PS is tight enough with ~165 uF (maybe 150) on the 4 power tubes? I say maybe 150 because mine check out at 300 uF each, not 330.
CHIP
Post by CHIP »
David Root wrote:It does look good! Thanx for sharing.
Yes David, I find the PS to be tight.
When you say "it does look good "do you mean the layout, or the ON ON switch?
tubedogsmith
Post by tubedogsmith »
Chip, on your PAB switch the side of the switch that connects to the bass pot needs to connect to the side of the r/j switch with the 100k resistor going to the treble pot. Sounds like you just need to switch the two wires going to the common on the r/j switch side to side. This is providing everything else is wired correctly on the switches.
I just went and looked at those layouts, wire it like the 102 RF layout.
CHIP
Post by CHIP »
Thanks, I'll check it out.
David Root
Thanx Chip, I'll use the same plate caps you did. I'll be using a quad of Mesa STR-415 (Sylvania 7581A) at about 500V.
I was referring to your layout and workmanship, not the switch wiring.
CHIP
Post by CHIP »
deleted
Chip the only reason to use a three position on-off-on for the Rock/ Jazz switch is for the middle position for PAB.
This just simply allows a front panel switch to be able to turn on PAB.
