Funkalicousgroove wrote:Max,
We are friends, and I do respect you, BUT:
At what frequency?
at what amplitude?
What equippment was used to measure the THD?
Typically one would use about 1/2v peak to peak(average guitar pickup) @ 1K-2K and have all the knobs maxed on the amp, and monitor the output to a pureley resistive load with an oscilloscope/spectrum analyzer/multimeter.  At those conditions I really DOUBT that amp made a
clean 50 Watts at the onset of clipping with only 3% thd.
Now, Increasing the input signal to achieve the voltage at the output is not a real world comparison if the voltage surpasses that of a guitar pickup, ie, it may make 50 watts with an ENORMOUS input signal, but that's not what would generally be plugged into it.
Alternativeley, one could plug signal directly into the input of the phase inverter, but it is only a fair comparison if the voltage is equal to what would be coming out of the last stage of the preamp at the above conditions.
I hate to be one to say this, but your last post may not contain 100% accurate information.
Hi Brandon,
I think I understand what you say and I will ask the tech who did the service and report.
You are right, was not very accurate:
I just would report my own impressions and those of some others who use(d) these kind of amps in regard of daily practice, from a gigging musicians point of view.
The measurement results I only reported in the sense of: "tech said everything working fine with new 7025 PI tube and new 7581A power tubes". But I really don't know  - without asking him - in what detailed way he made sure that the amp is working fine with these tubes. When I've talked to him, I'll report the results.
Perhaps the amps you and I are talking about are different in some way and this difference is the reason of our different observations in regard of possible PI tubes?
I always wondered, why me and some of my friends didn't like the AT7 as usually it has always made sense to follow Alexander's recommendations and what he specified for his amps. Perhaps it is only a matter of my (bad?) personal taste?
Just as I write this I seem to remember, that I know of one or two ODRs where I liked the AT7 better and the 7025 didn't deliver as good results as PI (for my ears).
What I reported "from the bench" may even have the reason that the tech thinks: "O.K. if you fools like the 7025 better, do it, the amp will not explode."
O.K. - no more speculation - I'll ask him about this.
Thanks for the criticism - open talk between friends is IMHO one of the best ways of learning I know. This is always welcomed and the more if it comes from you.
Have a great time and all the best
Max
