Bob-I wrote:I don't see anything really wrong with your construction. It may be an optical illusion but the snubber look wrong. There should be 270pF caps from 1-3 and 6-8, they almost look like they're from 1-2 and 6-7. .
I'll double check, but they should be right.  I just swapped the 270's with 330 pf's on dogears' recomendation, so it's entirely possible that I didn't wire the new ones up correctly, but I'm fairly certain I did.
Bob-I wrote:
What caps and resistors did you use?
The caps are OD's.  I believe they're 715's, but I'll check.  Interesting that they sound brittle, if that's what they are.  I'll check.
Bob-I wrote:
I've found that some of the cheep metal film resistors really sound outright bad. I went to Vishay Dales on dogears' recomendation and the difference was amazing. Since then I've used some quality carbon films and they sound decent compared to the Vishay's but far better than the metal films.
The resistors on the main board are all either carbon comp or carbon film.  Not sure of the brand, though.  These Visay Dale's, is it worth going through the exercise of removing all of the existing resistors and putting in Dale's?  I can do that, but I wonder if it will be a lot of work with no audible result?  I suppose it's hard to say until I do that, though...
Bob-I wrote:
The lead dress that should be used on V2 is a bit against the rules. Take a look ath this thread and you'll see that the cathode and plate leads run parallel. Apparently Dumble used this for some reason unknown to us here, but it makes a difference.
Thanks for the tip.  I ran into a problem in that the tube sockets I bought are oriented such that they had to go in this way.  So what I tried to do was make sure the grid and plates didn't run prallel, but crossed at 90 deg where necessary.   On the layout diagrams they're rotated 45 deg, I think, and it makes it easier to run the cathodes and plates parallel and right to the board.  Question:  can I do something about it as is?  I mean, if I run a longer cathode wire from pin 3, I could route it around the right side of the socket so at least they'd be parallel untl they reach the board, then I'd have to snake the (black) cathode wire under the board behind the other wires and up to the cap and resistor where it's supposed to go.   What do you think??
Bob-I wrote:
I also see a white lead from the master that seems to run parallel to the DC voltage for the relays. I may be wrong, it's hard to see, but if that's the case I'd move those leads apart.
You're right.  I can separate these.  I figured DC wouldn't have any effect on a signal.  Is that not true?  (this is all a grea learning experience!).
Thanks for the input.  So:
TODO:
- double check the snubber location
- move the master lead away from the DC relay supply
Questions:
- is it worth buying all new PS caps?
- is it worth swapping out all the resistors for Dale's?
- is it worth adding longer plate/cathode wires on V2 so I can
  make them run parallel for a while??
Mark.
