rootz wrote: ↑Mon Jul 31, 2023 2:16 pm I understand one can get overwhelmed by the complexity of an ODS. But trust me when I say that the different ODS amps are more or less variants of one another. That is where I and many other members (I admit I take some liberty here) can help you: make the variant you want.
So, let’s assume you have a (verified) small special schematic. That is some sort of clean only ODS. No relays, no OD stage. Let’s say you really like the Bluesmaster cleans (just as an example). Then I can help adjusting values in the layout to Bluesmaster values. It’s not difficult once you understand the basics of an amp and/or an ODS. You’ll get to understand more along the way.
On a side note: there already is something like a clean only Bluesmaster. It’s called the Ultraphonix mod for a Bandmaster. There are plenty of video clips of either Bluesmaster clean or a Dumble modden Bandmaster. The modded Bassmans are something different though.
I must also note that IMHO ampgarage is one off the best and most helpful forums I’ve ever had the pleasure off visiting and being on.
thanks. ill definitely be looking into clean clips. I think thats where ill start. id ultimately like to pick a ODS clean channel that taxes pedals the best and has the best sound on its own (or maybe with a little added reverb in the loop.
im also thinking the regular ODS chassis is the way to go and I can just not use some of the holes on the front or back and cover with custom faceplates. plus it gives me room to add or take away features as desired.
is this the sound of the ultraphonix blues master (even if its in a Marshall?) because this sounds good to me
https://www.youtube.com/watch?v=mZJcXrciKug
im still looking to find some blues master clips
