Check this out......
Aaron
Re: Check this out......
Post by Aaron »
These are what I use
http://www.jaycar.com.au/Interconnect/P ... t/p/PS0182
Look very similar
Aaron
ayan
Post by ayan »
redshark wrote:Both jacks, the Kobiconn and the Calrad don't look like the one in the picture. Any other input jack options?
I wonder if you saw my post, right above yours... listing the actual part used by Dumble. I'm reprinting it below in a slightly larger font so you can more reaidly see it. :)
G.
They are "isolated make" jacks and the correct part number(s) is(are):
Enclosed Version, Nylon Bushing (Used by Dumble)
Switchcraft N113X
Open Frame Version, Metal Bushing (Common Replacement)
Switchcraft 13
Both available from Mouser by adding "502-" in front of the P/N
redshark
Post by redshark »
Thanks a LOT Ayan!!
Aaron
Post by Aaron »
redshark wrote:I just opened up this amp. I will post some pics. The only wood board is the one with power caps. It has 3 boards for 3 diferent preamp sections. Input, overdrive and phase inverter. The OD trimmer is glued. Seems to me they liked that setting. The amp is not gooped so all can be seen. Great sounding amp here!!
Any chance of some pics soon?
Aaron
redshark
Post by redshark »
Yes, but the owner for a while has decided not to publish the pics and I have to respect his decision.
Later he may change his mind. The amp needs some maintenance work. I may do part of it and the other part of the maintenance may be done by an active member of this forum with more experience on Dumbles, I'm a trainwreck guy by the way. So I will do common service and the parts that requiere more D experience will be done by him.
Thanks!!
Smokebreak
Post by Smokebreak »
What a tease!
redshark
Post by redshark »
I'm replacing filter caps. I will post pictures soon!! :) Before and after ;)
Does anybody know what did Howard use to glue the filter caps to the board? that stuff is nasty!!
GPD
RTV Silicone
Post by GPD »
HAD seemed to be a big fan of silicone RTV...
In the 1970's, it tended to be black in color. You'll see blue liberally used (abused) when he started gooping the components of the V1/V2 region of the pre-amp board during the 1980's.
Before the "gooping" began, he used it for structural stability (protect from vibration breaking solder joints or to keep things in place, like relay covers).
As the years progressed, he used it for both purposes...structural integrity along with to ward off copycats.
Hope this helps.
Aaron
Post by Aaron »
redshark wrote:I'm replacing filter caps. I will post pictures soon!! :) Before and after ;)
Hint: When using RTV and you don't want it to stick to you, a bit of spit on your finger will stop it from sticking and you can smooth it over.
Also, can't wait to see some pics of the amp, intrigued by the PCB design.
Aaron
redshark
Post by redshark »
This is the bad boy.....more pics later :D
FuzzFaceBuilder
Post by FuzzFaceBuilder »
Dang! I've always wondered the chassis layout for PCB ODS amps. Between this and the Rick Vito ODSR we've got two great examples! Thanks again Redshark!
Aaron
Post by Aaron »
Thanks Redshark :D
Very interesting layout. The question is, why did HAD decide to do a completely different layout and circuit board for this amp?
And, how many more PCB amps are there?
Thanks again,
Aaron
Aaron
Post by Aaron »
FuzzFaceBuilder wrote:Dang! I've always wondered the chassis layout for PCB ODS amps. Between this and the Rick Vito ODSR we've got two great examples! Thanks again Redshark!
The Rick Vito is still point to point, it's just a different layout.
Thanks,
Aaron
FuzzFaceBuilder
Thanks,
Aaron
Was just going on memory re: Rick Vito ODSR. Thanks for the clarification Aaron.
Thanks,
Hale
