talbany wrote:the DL being a 12BH7/7025 combo and the SSS being (predominantly)7025/7025.
So perhaps I remember wrong. I always thought that Brandon posted:
DL 150W: 12AU7 > 12BH7
SSS 150W: EJ version 7025 > 7025 ..... SRV version: 12AU7 > 12BH7.
So I misunderstood what you posted here concerning the PI >driver circuit of an Odyssey? I ask, because I always thought that in your opinion the 12AU7 > 12BH7 circuit of an Odyssey 100W has a different structure (and not only different tubes) than the 7025 > 7025 circuit of a SSS 100W?talbany wrote:AFAIK the circuits would be very similar and are interchangeable with balance and re-bias so this should go under tube compliment correct?
And from this (misunderstanding?) I always concluded (up to now) that in your opinion the structure of the 12AU7 > 12BH7 circuit of a DL 150W is different from the structure of the 7025 > 7025 circuit of some 150W SSSs, too.
And based on this (misunderstanding?) I concluded that in your opinion the structure of the 1 x 12AU7 > 2 x 12BH7 circuit of this DL 300SL is different from the structure of the 7025 > 7025 circuit of some 150W SSS.
So if your opinion is, that the structures of all the PI > driver circuits in all these Dumble amps (SSS 100W, Odyssey 100W, DL 150W, SSS 150W, DL 300SL) are identical and only the tubes used in these identical structures are - for whatever reasons - different, than I simply misunderstood what you posted concerning all this up to now. If so - I'm sorry for any confusion that my misunderstanding might have evoked.
BTW: IMO the OT of this SRV SSS 150W posted here looks rather similar to the OTs of DL #009 and of the DL 150W of Jackson Browne - now probably owned by John Mayer (you'll find pictures of these DLs posted in some other threads here). And based on its output-impedance switch, this SRV-SSS 150W has at least a different OT (4, 8, and 16 ohms switchable) than the SSS 150W described in the SSS 150W data sheet posted here ("4 and 8 ohms switchable").
... details - details - details ...
Max
