Niki
Tweedle Dum - Completed
Re: Tweedle Dum - Completed
Great build. Nice and clean (gotta learn how it's done somewhen
Niki
Niki
Alumamark?
dcribbs1412
Re: It Lives
Great idea TMToneMerc wrote: FWIW, PT is 326.5-0-326.5 but HT current rating was setup to run both 6V6 and 5881.Thus PT is not loaded as heavy as the stock type units.
TM
your chassis and face plate looks great
Darin
Re: It Lives
Thanks Darin, it didn't make much sense to chase down simlar PT's already on the shelf. I will pop on the JJ 6V6's later and document any volatge changes verses the TAD.dcribbs1412 wrote:Great idea TMToneMerc wrote: FWIW, PT is 326.5-0-326.5 but HT current rating was setup to run both 6V6 and 5881.Thus PT is not loaded as heavy as the stock type units.
TM
Darin
Mike
Installed the JJ 6V6's with no other changes and the line voltage is the same as above.
V3 & V4: 398V plates, 358.5V screens, 24.14V cathode
TM
TM
Jelle I think the faceplate is Mojotone brushed silver front engraved acrylic.Alumamark?
Man, did you finish? I'm interested.
What cat resistor did you use for the power tubes?
Do you have a spare chassis?
