The bleeder only affects the preamp rail and should be in the circuit and yes that is typically the bias range of a Dumble ODS, you can season to taste. So, now you are about 15-25V too high on the plates.Smokebreak wrote:Thanks TM, i just put it in, but my issue still is upstream at the 6L6gc plates, or what I believe to be the PT. My plate voltage, at 33mA is 480VDC. Increasing the bias to 45mA or so only drops Vp a bit.ToneMerc wrote:You need to hang a 150k bleeder off of B5+ to draw down the preamp voltage rail, without it V1-V3 wil be about 22-25V too high. Also bias should be adjusted to around 32-35mA.
TM
Even if I was looking for 480V plates, are these amps usually biased that cold? And are there voltage charts around for these 50W D'lites?
On my 50W D'lite I'm running around 465-470, but that is by design.
Here's some typical voltage ranges that you can kind of ball park
PI: 275-310
Plates: 445-465
TM
