#183 ways to get more gain?
Jhyatt2012
Re: #183 ways to get more gain?
Post by Jhyatt2012 »
Cameron wrote:
Jhyatt2012 wrote:I've got it going from the OD vol to ground. Tried different variations with resistors from diode to ground with no real significant difference. In just playing around with the switching, though I jumped the wiper from the od drive to the master wiper. Put it all on a DPDT and it works pretty good.
What diodes are you using?
mostly 1N4007's
Cameron
Post by Cameron »
mostly 1N4007's
That will cut the signal way too much. Go get some 11 volt (1n4741) and 20 volt(1N4747A) zeners. If this is all you have..and you have 5...try the bridge rectifier style clipping..like in the JCM 900 after the 3rd gain stage.
Jhyatt2012
I will have to try the zener diodes. This is all turning out to be a really fun mod to do :D
Phazor
Post by Phazor »
Ayan wrote:
For my taste and with all of my guitars, the OD always sounds "better" the higher the preamp's (V1A) volume control is set. Gil
This statement really helped me to get closer to that better Dumble OD tone I have been chasing for a long time. I have a fender and the normal channel is a dumble preamp with the tremolo tube used for the OD. I have struggled with this for a long time to realize that opening up the V1 volume makes a huge difference in the tone. I have set up the clean channel and then dial in the OD. Now I'm convinced the OD should be set as Gil says with V1 Vol. up and then dial in the clean. On the other hand the clean from the reverb channel is to die for and so I try not to mess with that function and really just switch with an ab box from clean fender to OD channel 1. This makes me want to put a 1meg with a relay from pin 1 vol pot to ground to lift the v1 level with OD and back to Vol 1 gain in clean. Interesting.
danotron
Post by danotron »
talbany wrote:
would default to turning the preamp volume (V1A, if you would) all the way up
Gil
Good idea you could alter the ground on the input pot..
Ground it in clean mode and lift it (whatever value sounds good in OD) put it on a relay that activates when you go to OD. :D
This what I have been doing....I lift the clean volume with a relay when I switch to OD. This alows me to set my clean volume where ever I want to. My OD tone is now independent of my clean setting.
In some amps I also switch to a trimmer to have a preset clean volume setting feeding the OD if I don't like the sound of the clean volume set on full.
Dan
The Blues is my Business....
and Business is good.....
Dan
Hi Dan,
Can you give a little more detail about this mod?
How does the OD (which is V1 + V2) get enough drive if the Clean volume is bypassed?
vibratoking
Post by vibratoking »
Tom. I think he is passing the full signal from V1a on to V1b when in OD mode instead of attenuating it with the V1 volume pot.
10thTx
Post by 10thTx »
Maybe something like this? Both relays switched simultaneously allow a strong signal to enter the OD channel?
With respect, 10thtx
Phazor
Post by Phazor »
10thTx
Thats what I'm doing next. Maybe a higher value than 220k but maybe just a 1meg trimmer. as mentioned in an earlier post.
Phazor
Post by Phazor »
All you really need to do in the example is put the 220k to terminal 1 of the pot with the other end(of resistor) to ground and relay across the resistor. That way there is no bounce to ground (I think), and requires only a simple single pole relay.
FUCHSAUDIO
Post by FUCHSAUDIO »
LeftyStrat wrote:Or try the FET input?
Ditto that, and Jose clippers....fear not the diode clipper. Pick the type of diode and series resistor correctly, and it ain't bad.
Heresy! Stay away from diode clipping and never look in my amps.
danotron
Post by danotron »
exactly like this!!
Dan
tag101
Post by tag101 »
CHIP wrote:I honestly have been considering trying to lower the gain in the OD of my 183 copy.
to each his own.
I hear you. I usually have V1 and gain at 9- 10 O clock. Maybe something else is not quite right and the amp is lower in gain than it should be?? Mullard preamp tubes are VERY gainy in Dumbles, I use lower gain GEs or chinese. Here is my Quinn 183 clone doing a HEAVY Sabbath tune (Into the void) with V1 and gain at no more than 12 Oclock. (Chinese 12Ax7s) Its at least as much gain as Iommi uses, and that is pretty up there in the gain department IMO. :wink:
http://www.soundclick.com/player/single ... i&newref=1
Damn I love that tone!!! (G12h30s)
VERY GOOD VERY GOOD!
Phazor
Post by Phazor »
tag101
I love that tone too. Its amazing how wide rage a dumble is. It sounds like hot pickups on the guitar. What are they.
I have an old set of G12H30s and always go back to them.
