New build complete: CE Silverface 6V6 HRM
ToneMerc
Re: New build complete: CE Silverface 6V6 HRM
Post by ToneMerc »
dreric wrote:TM
As usual, the build looks great. I'm always impressed with your part selections. Seems like your are straying from the 6PS convention, care to fill us in on your cap choices and the thoughts behind them?
Is that a switch on the back of the mid pot! For?
Also, I'd second the request for a copy of the main board layout. I have a custom rj chassis that I had made up a 6V6 HRM and the board would move the project along nicely.
Thanks for your consideration.
Eric
Thanks guys.
Parts selection: Eric as far as parts selection I'm just sort of following HAD's lead and there's some experimentaion. While I do believe there are certain part recipes for certain circuits, I also believe a good amp can be made with "alternative brands".
In the later amps you start to see more usage of NTE metal films, a CGW thick film resistor on V1 and also several different types and brands of caps particularily in the PI secton. For example, you see amps with AE (blue) .1 caps in the PI. I ran across some AE .1's and figured why not try them.
Mid pot: pull it to lift the HRM tone stack.
Layout: here's a main board layout, only difference is that it has the standard(pf cap mounted on the mid boost switch) treble cap/midboost layout.
Also Eric, I like the general setup as you can just pull the four 6V6's, install two EL34's and just rebias.
TM
talbany
Post by talbany »
Mike
The build looks great!!...Please post a review..BTW I have heard mixed reviews on the Dumbles loaded with (AE) Blue caps..EM's are smooth caps!!
Good Luck!!
brewdude
Post by brewdude »
ToneMerc wrote:
ToneMerc, would it be possible to post the HRM-BRD_4.0.vsd file as a pdf?
ToneMerc
Post by ToneMerc »
brewdude wrote:
PDF it is
TM
Are the AE caps Arco Electronic?
brewdude
Post by brewdude »
ToneMerc wrote:
brewdude wrote:
PDF it is
TM
Thank You.
ToneMerc
Post by ToneMerc »
Structo wrote:Are the AE caps Arco Electronic?
Possibly, that's was kind of my conclusion when I faintly researched them way back.
TM
ToneMerc
Post by ToneMerc »
brewdude wrote:
ToneMerc wrote:
brewdude wrote: ToneMerc, would it be possible to post the HRM-BRD_4.0.vsd file as a pdf?
PDF it is
TM
Thank You.
You're welcome.
TM
dcribbs1412
Post by dcribbs1412 »
Looks like a great versatile build TM
Looking forward to your thoughts on the caps, and the build in general.
Darin
ToneMerc
Post by ToneMerc »
Yep, I'm slow. I just need to add the few components across the front controls, tack in the buss bar and drop in the string resistors. I think I will fire it up with EL34's this time.
TM
stelligan
Post by stelligan »
Still following this one. Looks great! Especially the big assed trimmers! You must be itching to flip the switch. Here's to a happy power up!
ToneMerc
Post by ToneMerc »
stelligan wrote: Looks great! Especially the big assed trimmers! You must be itching to flip the switch. Here's to a happy power up!
I hate the smaller 6mm and 10mm trimmers when using eyelets. Funny thing is, not really. Around 3 weeks or or so I sort of felt like Forrest Gump when he up and quit running across country. I think that was a sign that maybe it's time to move on to something else. I do have a few build projects to finish up though.
Thanks for the kind words
Mike
dreric
Post by dreric »
Mike
Looks like you are using one our your fancy custom Heyboer PTs. What specs do you order? If 6V6 and EL34 are interchangeable, you got the heater amps to be ? If you don't mind me asking, what was the cost?
I've got a few PTs from 2 6L6 Fenders I was going to use for my build but I haven't thought them out quite yet.
Build looks great!
Eric
ToneMerc
Post by ToneMerc »
dreric wrote:Mike
Build looks great!
Eric
Thanks Eric
Pri - 122V
Sec - 295-45-0-295 @ 400mA This PT I dropped the HT voltage slightly, previous quad 6V6 builds were 307-45-0-307.
6.3V @ 500mA
6.3V @ 5.5A, which is plenty for a 6V6,6l6 quad or a pair of EL34's.
IIRC, $118 shipped
TM
dreric
Post by dreric »
ToneMerc wrote:
dreric wrote:Mike
Build looks great!
Eric
Thanks Eric
Pri - 122V
6.3V @ 500mA
IIRC, $118 shipped
TM
Now I get it!
Eric
