Hey! Don't sweat it
I'd be a bit leary of sheepshit-inspired-whisky but it's a nice antidote to the whisky-inspired-bullshit found elsewhere
Hey! Don't sweat it
Agreed, and great to hear it. I'm very interested in the 183 and looking forward to more progress shots. I just completed a 50W P2P #124 without OD, an affront to convention in all respects, but it sounds great. Onward and upward!Stephen1966 wrote: ↑Wed Jan 04, 2023 9:58 am
Hey! Don't sweat itIt's only because my soldering station died over Christmas that I haven't been posting amp goodies, but it will be returning soon I promise you.
I'd be a bit leary of sheepshit-inspired-whisky but it's a nice antidote to the whisky-inspired-bullshit found elsewhere![]()
That's interesting... 4 tubes! I imagine it will make a neat little combo. Did you use the Skyline tonestack? It's approaching a Tweedle-Dee, I wonder does it break up in the same way at higher volumes?ViperDoc wrote: ↑Wed Jan 04, 2023 3:19 pmAgreed, and great to hear it. I'm very interested in the 183 and looking forward to more progress shots. I just completed a 50W P2P #124 without OD, an affront to convention in all respects, but it sounds great. Onward and upward!Stephen1966 wrote: ↑Wed Jan 04, 2023 9:58 am
Yes, it's a Low Plate Skyliner build. It is incredibly clean generally but definitely breaks up nicely when pushed. I used Merc Mag iron and tried to get as many of the right corks in the right bottles, although particulars in the wild are difficult to find these days, I understand. The amp sounds awesome, although I do have Beyschlag MF on the P.I. plates. I might switch out to Kiwame CF if I can find them (124 calls for CF on PI plates). It sounds great as is, though. It can get into legendary rock territory, especially with the PAB and the MID boost paired up. I'm still exploring it.Stephen1966 wrote: ↑Thu Jan 05, 2023 1:58 pm
I think I might have posted this link up already, but here is where I get mine from: https://www.hificollective.co.uk/index. ... iwame.htmlViperDoc wrote: ↑Thu Jan 05, 2023 3:20 pmYes, it's a Low Plate Skyliner build. It is incredibly clean generally but definitely breaks up nicely when pushed. I used Merc Mag iron and tried to get as many of the right corks in the right bottles, although particulars in the wild are difficult to find these days, I understand. The amp sounds awesome, although I do have Beyschlag MF on the P.I. plates. I might switch out to Kiwame CF if I can find them (124 calls for CF on PI plates). It sounds great as is, though. It can get into legendary rock territory, especially with the PAB and the MID boost paired up. I'm still exploring it.Stephen1966 wrote: ↑Thu Jan 05, 2023 1:58 pm
You're the second person to recommend that place. Thanks, I appreciate it. Now I know where those pink resistors come from!Stephen1966 wrote: ↑Thu Jan 05, 2023 3:58 pm
I have been using those resistors lately and I like them a lot too!rccolgan wrote: ↑Fri Jan 06, 2023 1:37 am A little secret, I'm 99% sure that the Kiwame resistors are SPR series Koa Speer (or the other way around?) These guys agree too: http://beezar.com/pho-bzr/catalog/produ ... cts_id=135
https://www.mouser.com/c/passive-compon ... series=SPR
I plan on using them a lot more in future builds. They sound fantastic!
-Ryan
Hi Ryan,rccolgan wrote: ↑Fri Jan 06, 2023 1:37 am A little secret, I'm 99% sure that the Kiwame resistors are SPR series Koa Speer (or the other way around?) These guys agree too: http://beezar.com/pho-bzr/catalog/produ ... cts_id=135
-Ryan
I like them as the final 2k2 voltage dropper on the power supply as well as 1.5k cathode resistors. My next amp I'll try to source as many as I can as the primary resistor and then fill in the gaps with something else. I wish they still had the 100k & 110k... Maybe they will reconsider in the future.jazzbass wrote: ↑Fri Jan 06, 2023 10:21 amHi Ryan,rccolgan wrote: ↑Fri Jan 06, 2023 1:37 am A little secret, I'm 99% sure that the Kiwame resistors are SPR series Koa Speer (or the other way around?) These guys agree too: http://beezar.com/pho-bzr/catalog/produ ... cts_id=135
-Ryan
in which positions will you use these resistors? the question will seem trivial but given the range of power dissipation they have they can be used anywhere.
Thanks, Frank
I'm interested in using the fast recovery RGP10M diodes in place of the 1N4007s as I expect the transients (switching noise) will be quieter. Frustratingly, I read here (somewhere!) that slugging caps shouldn't be used with the superfast switching diodes because they interfere with their operation, but without any explanation of how or why. So I breadboarded the rectifier circuit, as a full wave bridge, and went hunting for the transients.Snubbing implies burning energy off as heat, whereas slugging capacitors only spread the energy out, transferring it to lower frequencies.
Excellent pearl, thanks for dropping it.rccolgan wrote: ↑Fri Jan 06, 2023 1:37 am A little secret, I'm 99% sure that the Kiwame resistors are SPR series Koa Speer (or the other way around?) These guys agree too: http://beezar.com/pho-bzr/catalog/produ ... cts_id=135
-Ryan
Great find. I think I saw a similar discussion elsewhere but this lays it out clearly. Thank youcys wrote: ↑Sat Jan 07, 2023 11:19 pm I found this discussion of caps with "slow" and fast diode rectifiers: https://ampgarage.com/forum/viewtopic.p ... 70#p277970
