Max - thanks for taking some time to chat about the SSS...
Max wrote:1. In this thread you see a picture of a SSS. Do you see something that looks like a SVT power amp?
2. SVT is 300 Watts. According to the known catalogues and SSS datasheets of Mr. Dumble there did never exist a 300 Watt SSS
Well nothing that looks like a 300 watt Output section anyway... but the driver tube and the filtering section teases us a little to believe there was a little something borrowed from AMPEG in the SSS. Also there is some folklore that floats about that makes this connection. If you know for sure then I don't mind putting the notion to rest.
Max wrote: 3. According to the posts by Brandon and myself (We both do at least have some personal experience with Dumble SSS) there are at least three different variants of SSS PI/Driver setups:
a) only one 7025 as PI as in every ODS
b) two 7025. First PI, second Driver. "Phase Inverter" and "Driver" are the names Mr Dumble uses for these. They have not been made up by me.
c) One 12AU7 as "PI", one 12BH7 as "Driver" like in a 150W Dumbleland.
This is a great contribution to us. Might explain some of the origin of the folklore and adds to the public knowledge base on these amps. Thank you for this, it is good stuff!
Max wrote: Perhaps it wood be a good idea if you
- first
decide what kind of SSS sound you liked best of those you have
heard live or recorded
-second
find out what special kind of SSS was played at these concerts or recording sessions.
-third
find out the technical details of this special SSS
I can see this could be useful if for the musician who has identified something very specific they want to hear from their amp, but that is not the case for me. I am an experimenter, builder, student, and teacher and knowing that these amps are famous for great clean tone and singing sustain makes the circuit interesting to me even if had never heard a sound clip from one of them. Sounding like SRV would be cool, but it's not a goal for me.
Max wrote: -fourth
decide if you want to take all the trouble of cloning this special SSS you've liked best or better to buy one of the amps you find on the boutique market (Bludotone, Two Rock, Fuchs and maybe others) that are offered as being (more or less) SSS clones.
Trying one of these may perhaps spoil the fun you may see in investigating and then cloning the Dumble SSS. But perhaps you would be revarded with more time for Rock'N'Roll.
You sorted that one out for yourself... buying an amp can't satisfy the amp builder habit much less the experimenter intellect.... maybe not a surprise response given that this is an amp builders forum. For me, even cloning an amp is not rewarding in the way that experimenting and sorting out what possessed the original builder to make things the way they did.
Max wrote: BTW: An original one that IMHO sounds really great (PI variant b)) is right now available at Overland Express.
I like this note... variant b sorta fits into some of my preconceived notions about what I thought I might build. I've seen a couple amps and even built one of my own using a driver tube and I liked the results. In this case I am really trying to grasp the concept of how that the driver tube is key to reducing distortion. That would be a useful piece of technology for other amp projects as well.
If you don't mind a little follow up discussion on the output section, I am curious if you believe that it is basically the same as the ODS? I see the Fender iron and it seems that the extra power supply stuff isn't obvious in the one SSS gut shot we've got. Four 6L6's or maybe 6550's and the iron is the same as an ODS? Curious if you can elaborate?
Thanks,
rj
http://www.rjguitars.net
