You run your knobs about like I do.
It will only get better from here on.
Do you know where your OD trimmer is set with the amp on?
Thanks! I'm pretty sure I set the OD trimmer to 25.3k to ground with the amp on.Structo wrote:Sounds good.
Right. That's why I changed it this morning.CHIP wrote:Nice job on the layout. It seems it may be confusing since the schematics show the jumper and then the original layout doesn't. I don't know why use the jumper if it doesn't matter.
I'm guessing it's a combination of that and the Power Transformer like talbany said. It's really not loud enough to be a problem even when recording, so I'm just living with it for now. Someday I'll probably try to trace it down, but for now the amp sounds so good that I'm reluctant to mess with it.jlatrace wrote:Did you finally determine the hum to be the tube in v1?
Thanks for the suggestion! I think I might reflow the heater joints next time I open it up. I was going to replace some of the carbon comps with film resistors to try to reduce the hiss anyway. I'm also going to try two 250pF caps on the send / return treble reduction network instead of 500pF that I have in there now. The 500pF seems to reduce the highs and subsequently the overall volume too much. Especially when that amp is at gig volume.jlatrace wrote:When you get back to it take a wooden chopstick and go over every ground, cap and heater joint. Give it a whack or push to see if you can get more than a hum.
Almost every time I have had hum gremlins they came down to either
1. Weak ( but not visibly bad) joint in heaters 2. Same thing at a ground point
But I'd guess a bad/ weak heater joint based on what all you have described.
Good luck, I chased one on these for a year in my 66 blackface DR before the joint got bad enough to be detected. It was a bad original solder joint under the board, I guess Leo missed it.
No problem, and thanks. I'm just glad somebody is finding it useful.jlatrace wrote:Thank you for the layout. In particular the lead dress detail is outstanding. I'm using it as reference in two builds I have going on, a 183 & another 102.
I used a bunch of the CCs in the signal path on the initial build. They are the rectangular looking brown ones on my layout. Last night I replaced a bunch of them with KOA speer carbon films, reduced the treble reduction caps to 250pF, and reflowed the heater joints. The hum and hiss is pretty much unchanged, but the amp does sound slightly different. It's a bit more stout and together sounding. Less wispy and diffused. I think a lot of that may be due to the negative feedback resistor now actually being 390R instead of 430R (which the old CC resistor actually measured). The 250pF caps in the network do sound closer to the D'Lator sound. That 220k resistor seems to knock off a bunch of volume though.jlatrace wrote: FWIW - I used carbon comps in my first 102 in the B+ dropping string for v1 & v2 (not in the signal path) and in the phase inverter and my noise floor is very low. So low that when I first hooked up my DLator (and before I learned how to use it) that I spent weeks tracking down the noise caused by me having the DLator return set too high. Also, I do not have the treble reduction network and the amp sounds fine, slightly bright without a Dlator and normal with a Dlator. You might want to remove the 500pf caps and play the amp a while before reinstalling the 250pf treble bleed caps.
