Try this, remove the 4.7K (in a temporary way) and get a 2.2K resistor and a 25K pot.
Play guitar at the volume level that you use the amp at (or want it to sound it's best at) and get someone to adjust the pot slowly. You'll have to take into consideration any changes in gain, but listen to where the tone sounds best.
The role of the feedback resistor is to provide damping, if you have two 65 watt Celestions and you're driving them with a 100 watt amp you'll need greater damping, if you're using a 22 watt amp, you may not need any damping at all. Likewise if you use the amp at bedroom volume levels you won't need much damping, but if you are using it at the top of it's limit you'll need more damping.
I am repeating myself, but the choice of the feedback resistor value isn't a firm value. While component values in the tone stack are firm values.
It's all food for thought.
