124 Layout Revised
talbany
Re: 124 Layout Revised
Post by talbany »
Here is the Visio of 124 so far if someone wants to add to the layouts authenticity..I do ask if you do to repost the Visio if you update it so others can do the same...Please feel free to change what ever you like as this is now property of the Amp Garage...If you don't have a copy of Visio and would like to add a comment about the type of componets or layout feel free to put it in a post so others can update it....If no one wants to fool with it I will be happy to nail it down it when I get back from vacation next week...Don't be shy please contribute.. Good Luck
Tony VVT
ic-racer
Post by ic-racer »
Here is the Fet board for #124...
JamesO
Post by JamesO »
Guys, this is awesome. It's helping me complete a build I got from VoodooBlues in a Funk chassis.
Question regarding the 330R resistor opposite side but between the 330R and 1N4003 diode by V6 and V7. What do the leads of that 330R connect to?
Also, if I'm not planning on using the half power switch, do I simply omit the yellow leads that run from pin 8 of V5 and V7 along with the switch?
ic-racer
Post by ic-racer »
JamesO wrote:Guys, this is awesome. It's helping me complete a build I got from VoodooBlues in a Funk chassis.
That 330R resistor and the diode are for the power light on the front panel. If you are not doing the 'half-power' then just bring all 4 6L6 cathodes right to the grounding points between the tubes (or put 1ohm resistors in series, as some people do).
JamesO
Post by JamesO »
Thanks, Racer.
I can see the resistor and diode that go to the light, but opposite those two is a 330R. I'm not sure what the leads of that resistor go to.
ic-racer
Post by ic-racer »
JamesO wrote:Thanks, Racer.
Ok, I see it now, the one floating in air. That one is not supposed to be there.
talbany
Post by talbany »
OK who dropped a resistor in my amp LOL!! .. I am working on updating the layout this week with the FET and bias board.. as well as the updated main board from martian.. Thanks for the patience.
Tony VVT
JamesO
Post by JamesO »
Haha, that makes much more sense. I was looking and looking at the schematic and couldn't see where it was supposed to go.
talbany
Post by talbany »
updated #124 Layout..
Updated again
dimitris
Post by dimitris »
Very nice layout.
One small error i spotted is that the wire from the bright switch should connect to the middle lug of the volume pot.
ic-racer
Post by ic-racer »
Another little one: FET component is rotated 180 degrees from where it should be.
This is minor, but by making the manual OD and PAB switches blue it implies they are toggle switches. But they were slide switches. Because of the switch function, the wiring between a slide switch and toggle will be reversed.
talbany
Post by talbany »
Updated
Tony, you need to run a ground from the 2x10 uf cap can over to the ground lug by the input jacks. Also, add a nut to the rectifier board.
MPM
talbany
Post by talbany »
Ta!!Da!!
Gettin frickin dizzy lookin at this thing
jelle
Post by jelle »
Tony,
Got another one for ya...
the parallel ceramic .01uF caps for the Jazz position to ground should be series to get 5nF.
Awesome layout! :shock: 8)
jelle
