Dlator Values
- Funkalicousgroove
Re: Dlator Values
All My values came from an actual unit pictured in the files section, it belongs to a member here.
the 3rd (Middle)knob should be turned all the way up unless you have REALLY hot signal from your fx unit.
I have seen a number of these units (pictures of course) with the 3rd knob on the back.
I have only seen the Dumbleator II with a choke, the part # on top of the choke is 73C18641-2 H5157908
The original power transformer from these was an off the shelf part made for tube volt meters, I can't find the choke anywhere, but my guess is it is another off the shelf part, it's teeny and open frame-
- glasman
Re: Dlator Values
I have looked at that loop as it is very similar. I the KOC loop is what Andy puts in the Fuchs amps. At least I think that may be the case.greiswig wrote:Not meaning to hijack, but...
Kevin O'C (London Power) has a series/parallel FX loop based on a single 12AX7 that can be put into an existing amp and uses the amps HV and filament supply. My guess is that a lot of people here are familiar with it from the TUT volumes.
How comparable is this loop to a D'Lator?
Gary
About 5 miles south of I-94
www.glaswerks.com
www.glaswerks.com
Re: Dlator Values
I suspect everyone on this board has see this picture of Roben Ford's guitar. However, look in the right lower corner and zoom in:Funkalicousgroove wrote: I have only seen the Dumbleator II with a choke, the part # on top of the choke is 73C18641-2 H5157908
.... I can't find the choke anywhere, but my guess is it is another off the shelf part, it's teeny and open frame-
1. RF's Dumbleator has a choke.
2. It is not open frame.
3. Looks like the ON-OFF, Standby and GROUND switches on the front panel have been deactivated (as well they should, IMO).
Some more information: the choke replaces the 15K resistor.
Gil
PS: More Info
Especially for my man Brandon, who has taken this art further than anyone else on the planet!
I have seen other good Dumbleators with chokes. In one of them, the choke is open frame, and the part number is:
17-7513
I hope this helps some.
Gil
17-7513
Gil
- Funkalicousgroove
Re: Dlator Values
That looks like a Deluxe reverb choke!
Here is the one I'm speaking of-
Re: pan over
No, I don't.angelodp wrote:I don't suppose that you have the full picture... panning right !
A
Gil
- glasman
Re: Dlator Values
Man look at the railroad ties on that tele....
www.glaswerks.com
www.glaswerks.com
Re: Dlator Values
Real nice tele.
Looks to have Jumbo frets, original bridge, 11-52 strings, action not too low, pups original?
anyone know it's story, what changes have been made?
Re: Dlator Values
I got several schematics of parallel/series FX loop, one of them from this forum called ¨fatman¨, but wander could you post here this KOC schmatics that is mentioned in the above quote? Thanks.glasman wrote:
I have looked at that loop as it is very similar. Tthe KOC loop is what Andy puts in the Fuchs amps. At least I think that may be the case.
Gary
Re: Dlator Values
Gary
- glasman
Re: Dlator Values
I don't have them in a clean format. Hand written notes I took over the phone.Sven wrote:I got several schematics of parallel/series FX loop, one of them from this forum called ¨fatman¨, but wander could you post here this KOC schmatics that is mentioned in the above quote? Thanks.glasman wrote:
Gary
Gary
www.glaswerks.com
www.glaswerks.com
Re: Dlator Values
KOC sells these as a kit, and it wasn't unreasonably priced when I got it. There is also a diagram in his TUT3 book, but it is copyrighted. So I'd be reluctant to post a diagram for fear of taking bread off the man's plate.Sven wrote:I got several schematics of parallel/series FX loop, one of them from this forum called ¨fatman¨, but wander could you post here this KOC schmatics that is mentioned in the above quote? Thanks.glasman wrote:
Gary
-g
Re: Dlator Values
I am 100% sure that Mr. O'Connor took many a bread from many a plate when he wrote his TUT book. But, never mind, let the man eat.
If someone wants to post shcematics, fine, if not, fine again.
Sven
Sven
Re: Dlator Values
I'm confused by what you mean by this.ayan wrote: Looks like the ON-OFF, Standby and GROUND switches on the front panel have been deactivated (as well they should, IMO).
Are you saying powering up immediately by just flipping the on switch on a rack mounted power strip will not harm the tube (i.e. no warm up needed)?? thanks
