Dumbleland update (was SSS) :D
Re: Dumbleland update (was SSS) :D
Hi,
Is that V1a/b or the buffer stage for the pi??
Just like the cathode direct coupled stage for the "200w bass amp" ?
It would be a great tube for that application because it is designed as a high symmetry driver and delivers a lot of gain. 70% compared to a 12ax7.
Interesting stuff. I love this subject!
Jelle
Jelle
- glasman
Totally OT, Jelle what part of the Netherlands are you located. I will be in Eindhoven on business for 2 weeks at the end of the month. Always fun to chat with tubeheads.jelle wrote: Interesting stuff. I love this subject!
Jelle
Tot Ziens,
Gary
About 5 miles south of I-94
www.glaswerks.com
www.glaswerks.com
Hi Gary,
What is totally OT???
You're welcome! Shoot me an email: jwelagen at hotmail.com
I live in Nijmegen. That's about one hours drive from Eindhoven.
Sure is nice to talk to tubeheads.
Hoe goed spreek je nederlands?
Tot ziens in Nederland,
Jelle
Jelle
- glasman
OT = Off Topicjelle wrote:Hi Gary,
Jelle
I have been to Nijmegen at few times at the Philips facilities (I work for ASML in Veldhoven).
As far as my Dutch, I understand more than I can speak. I will drop you a note when I get in the Netherlands.
Gary
www.glaswerks.com
www.glaswerks.com
Hi guys,
I just tried the EF86 preamp and I like it!
It's very hifí-ish, clean and definately SRV- territory. Think 'little wing' and the album 'Couldn't stand the weather' in the 'jazz' mode.
I found out that the NFB is a must to keep the noise down, unlike the ODS. Also I was lucky to have three EF86 tube because one was extremely noisy. I run the signal from the second EF86 through a .047uF into the pi via a standard 1M master pot. AB763 solid state rectified into 15'' JBL K-series.
This is a not sound everybody will enjoy playing! Like playing through a magnifying glass, if that makes sense....
I've always wanted to hear the guitar like it sounds unamplified. This is it!
Electronavalanche: thanks so much for sharing this information. This is exactly why I bought a soldering iron: SSS-sound!
What's the latest news on the direct coulped phase inverter? Is it working and are there schematics available?
Jelle
The Netherlands
Jelle
The Netherlands
- ElectronAvalanche
Hi Jelle,
thanks for the report.
The SSS PI and post PI CF parts are as follows:
PI: 120k anode resistors
1M grid resistors
820 Ohm cathode, 24k tail resistor
Feedback Loop resistor 100 Ohm , 2k2 on Presence Pot to ground
Post PI CF:
150k CF grid resistors
100k (2W) cathode resistors
Think of the SVT 12BH7: coupling to Bias is with 330k , 30k
Here is a pic attached to make more sense....
I nearly finished that SSS amp, after looking for hours at the photocopied pics I had of the amp, endless planning and stuff, but the amp is lost forever I am afraid....
Electron
1M grid resistors
Post PI CF:
Electron
I've been wondering about the layout of the preamp ever since I saw the mini-pic at http://blueguitar.org/new/pix/sss12ax7.jpg
Can you put up a drawing or photo of how that works, with the tube sockets mounted in the middle of the eyelet board?
Thanks for all the info!
I have worked on this amp and it is not an s.s.s. It is more like a dumbleland.
Jay
Jay
Hi,
Can you explain the differences between the sss and the dumbleland?
Are there ef86's in a sss?
Electronavalanche:
Thanks for the info!
I can't find the attached picture in your message...
I'm very interested in some sound clips. Great work, very neat looking.
I'm also planning to build a sss. Did you use the reverb section from the ODS reverb schem?
oldmacman wrote;
Posted: Mon Mar 06, 2006 10:41 pm Post subject:
I'll try to figure that one out this weekend. So this is a 12ax7 sss, right?
Is the tube socket physically connected to the eyeletboard or is it underneath it? space saving measure? If only somebody would post some hi-res pictures of a sss....
How many tubes are there in a sss?
FWIW, with the enormous amount of gain of the ef86 I was very carefull with the lead dress! A couple of months ago I reworked the lead dress of a couple of homebrew amps which I thought I'd done well but there was a big difference after the lead dress was redone! Nowadays I design the schematic, then the layout on paper(!) and start soldering when I'm happy with it. Works for me.
Jelle
Electronavalanche:
oldmacman wrote;
Jelle
Please explain how you "improve" lead dress. What are you looking for? What constitutes "good" lead dress? "Bad" lead dress?
I have had 4 s.s.s. in my shop ,they all used feedback in each preamp stage and they had e.q. switchs. The early ones used cathode feedback and the later ones used feed back like the ods.
- ElectronAvalanche
@Jay,
which amp are you referring to? Dumblelands usually have more than 4 Output tubes.
The small pic of the 12AX7 shows a SSS as well, me thinks. I think I have seen the complete pic and the amp says Steel String Singer on the front.
The silver alligator SSS with the EF86 is a SSS as well.
@Jelle
the tube sockets are mounted on the chassis. Short wires run from the board to the socket underneath. I really do not know why Dumble choose to do it like this. It is a pain to service and to build. Maybe short leads?
As far as I know the Reverb from Dumbles ODS Reverb amps is identical to the SSS Reverb. But who am I to know!
Electron
@Jelle
Electron
I have pictures of the amp and know the history, Dumble was so unhappy with that amp he gave it away and than it was traded for a overseas ods
I saw it again when it came back .The letters on the amp are stickon and
and it is not a s.s.s
- Funkalicousgroove
Nevermind, got it
Last edited by Funkalicousgroove on Fri Oct 31, 2008 2:21 pm, edited 1 time in total.
