ok with this voltage you are on 100-110% means you are running your amp in class A, not class AB, which is good tone-wise.
but not for the life od the output tubes! maybe you can reduce little bit currents , adding 50 Ohms in series with cathode resistor, so total would be 250Ohms+50=300 Ohms which will bias lower your amp.
situation now:
voltage on each 6V6 is : Vak=375-21=354V
through the cathode resistor 4 currents are passing, V3-a, V3-g2, V4-a, V4-g2 and their total sum is
cathode voltage/resistor value = 21,3/250=0.0852 A = 85mA
this divided by 2 , thru each 6V6 passing half= 42,5mA
this multiplied with the voltage 354V= 0.0425*354=15W
means, over the max dissipation of the 6V6.. if we assume g2 current is cca 4-5mA, then anode current is around 37mA, Padiss =13.5-14W, still is over normal biasing range of 65-70% of max dissipation /6V6 has anode dissipation od 12W, JJ claims 14W
tonewise you are close/or you are in/ class A so your amp dimmed will not go in farting blocking distortion, or will but effect will be reduced, which is good, but from dissipation aspect , 6V6 is working on 110%, and their life will be shortened due to excessive heat.
current can be dropped in two ways, reducing voltage on g2 grid , Vg2 , inserting resistor of 500-1000ohms 5W in Ub+ line going to g2,
or incresing cathode resistor for cca 30-50 Ohms doesnt matter the value, just to choke little bit anode current.
