It's a Dumble and looks to be a .01
jcsifu wrote: ↑Fri May 24, 2019 2:07 am Hi Tony,
I should have been clearer that I was referring to the OP's choice in what I assume are 225P caps in certain locations as my post did come right after your post on the switch. I am familiar with the strat switch as well, though. I've added it to few peoples amps as well as at least 1 of mine and I will use on occasion but I usually come armed with a Les Paul.
JC
Ya those are Panasonic ECQ 630v polyester film foil. I used them for the .01 and the .1 in the phase inverter. I just wanted to experiment, the lower voltage ones are used a lot in pedals so I wanted to try them in a amp. The little blue ones are murata monolithic ceramic 1kv once again just experimenting no real rhyme or reason. They work and didn’t blow up that’s about all I can report. The Panasonic’s are interesting because identifying the foil was a lot easier. I did it the cheap method into an amp and the foil was strong more so than the cde 6ps.
Whoa that’s cool. Am I understanding that switch correctly, when you pull it it replaces the .01 in the circuit with that of a different value like .047 ? Oh wait now that I look again it’s just adding it.
The last set of 6PS caps I had I found it very hard to find the outside foil using my tried and tested 'cheap' method like you. The older,larger 6ps it was easy to hear but the new ones are either better made or something's changed as I think you'd need a scope now to reliably tell. That may mean it's not as important, who knows?Abe5150 wrote: ↑Fri May 24, 2019 4:48 amYa those are Panasonic ECQ 630v polyester film foil. I used them for the .01 and the .1 in the phase inverter. I just wanted to experiment, the lower voltage ones are used a lot in pedals so I wanted to try them in a amp. The little blue ones are murata monolithic ceramic 1kv once again just experimenting no real rhyme or reason. They work and didn’t blow up that’s about all I can report. The Panasonic’s are interesting because identifying the foil was a lot easier. I did it the cheap method into an amp and the foil was strong more so than the cde 6ps.
 I interpreted it differently. I may be wrong but the way I see it seems like a good solution. I'm seeing it as a .047uF and .01uf in series which gives you .0082. When you pull out the pot/switch, the .01uf is shorted out and you have .047.
I'm familiar with those caps in the 50v version for just that reason. They were very nice to implement in pedals, which is how I started changing my tone and later building my rigs. I was unaware the ECQ had a 630v versionAbe5150 wrote: ↑Fri May 24, 2019 4:48 amYa those are Panasonic ECQ 630v polyester film foil. I used them for the .01 and the .1 in the phase inverter. I just wanted to experiment, the lower voltage ones are used a lot in pedals so I wanted to try them in a amp. The little blue ones are murata monolithic ceramic 1kv once again just experimenting no real rhyme or reason. They work and didn’t blow up that’s about all I can report. The Panasonic’s are interesting because identifying the foil was a lot easier. I did it the cheap method into an amp and the foil was strong more so than the cde 6ps.
Ya I am looking at them right now on Mouser. I was surprised too when I saw them. They are pretty much the gold standard for pedals. I wonder how a whole Dumble in those caps would sound.jcsifu wrote: ↑Sat May 25, 2019 1:40 amI'm familiar with those caps in the 50v version for just that reason. They were very nice to implement in pedals, which is how I started changing my tone and later building my rigs. I was unaware the ECQ had a 630v versionAbe5150 wrote: ↑Fri May 24, 2019 4:48 amYa those are Panasonic ECQ 630v polyester film foil. I used them for the .01 and the .1 in the phase inverter. I just wanted to experiment, the lower voltage ones are used a lot in pedals so I wanted to try them in a amp. The little blue ones are murata monolithic ceramic 1kv once again just experimenting no real rhyme or reason. They work and didn’t blow up that’s about all I can report. The Panasonic’s are interesting because identifying the foil was a lot easier. I did it the cheap method into an amp and the foil was strong more so than the cde 6ps.
TonyI think so, But it looks a bit overkill. I can't see the loop pulling that much currentnorburybrook wrote: ↑Sat May 25, 2019 9:39 am Tony, is that big resistor there as part of the dropping string to power the op amp FX loop?
M
