"IT IS ALIVE"
Apart from a bad new input jack? Amp fired right up worked perfectly
 Voltages settled out
B+1 695
Screens 345
PI 280/287
V2-223/220
V1-213/214
  Voltages on V1 and V2 are a little high if I lift my 10k dropper to around a 12K (like Dumble did) would be about perfect!!
  However, I am digging it!
  I exchanged out the MK'3 plates for period correct (1981) Dale's like the ones used in the Ultrasound amp was a nice upgrade! (Thanks to CW) The amp sounds good with either LNFB V1b on or off, however, I actually prefer it on when in OD. Unfortunately, one of my new TAD EL-34's didn't light so I am not able to give a full review or do clips until I get the amp with a fresh set and dialed in. I still have to wire up and adjust the FET (I may put that on a relay as well).As soon as I do I will give my full review and let you know what I think.
  The main difference between my amp and the original Ultrasound amp are?
Mine has
 Classic Power supply w/ 3 150W Zener start-up diodes
50uF more filtering on the plates (To help keep the 34's tighter longer)
25uF more filtering on the screen supply for better regulation on new production EL-34's
Polystyrene .01 OD1 cap instead of the usual PS series for a slightly tighter bass response of OD side
2uF Presence cap instead of a 1Uf ala 102 value.
Apart from the power supply all of the values are just as the Tan Ultrasound Music Man amp.
Hope you enjoy the shots and let me know if you have any questions!
 Happy 4th of July.
