Dumble Overdrive Special #124 build video series
j0k3335
Re: Dumble Overdrive Special #124 build video series
Post by j0k3335 »
pompeiisneaks wrote: Fri Feb 23, 2018 5:59 pm I'll be livestreaming the dumble build process Saturday 2/24/2018 11am PST, 2pm EST, please join in!
... as you could imagine, pompeiisneaks/Phil, this topic, all these vids and explanations is wonderful for a newbie like me :D
Thanks a lot :wink:
pompeiisneaks
Site Admin
Post by pompeiisneaks »
Thanks a lot :wink:
You're very welcome. I'm learning too mind you :)
Phil
Sent from my LG-V521 using Tapatalk
tUber Nerd!
rccolgan
Post by rccolgan »
Really great series! I can also appreciate you shooting the video in 4k! You must be a video guy too like me. 8)
Ryan
https://www.thetonegeek.com/
pompeiisneaks
Site Admin
Yeah I'm a video nerd, still wish I had the ability to do more but time is my limit. I have a Sony A7RII and love it. I still end up messing up focus often because I'm using Canon EF glass on it and the auto focus doesn't work for shit. I need to get a monitor setup so I don't mess that up.
~Phil
tUber Nerd!
pompeiisneaks
Site Admin
Here's video 6 in the Dumble Overdrive Special #124 build series
Also, I'm going to be livestreaming tomorrow at 11am PST 1pm EST. Join me in the shop!
tUber Nerd!
Charlie Wilson
Post by Charlie Wilson »
Phil,
That filter cap on the input side of the chassis grounds with the rest of the preamp grounds under the input jack.
CW
pompeiisneaks
Site Admin
Cool thanks, I was having a hard time telling, glad to have someone confirm that!
~Phil
tUber Nerd!
pompeiisneaks
Site Admin
I'll be doing another livestream tomorrow, come join the fun! 11am PST, 1pm EST:
~Phil
tUber Nerd!
Charlie Wilson
Hello Phil, a couple things. Most the guys are using ceramic disc for the 270pf snubbers on the OD tube. They roll off some top end and smooth the overdrive. You are building a Low Plate Classic so maybe you will prefer the higher 300pf value(maybe not). You are using RG59 style coaxial which is a bit of a challenge(pain), you are going to want to wire up all of the coaxial and run a buss bar across the pots before you mount the board. Also have your relays wired up.
CW
pompeiisneaks
Site Admin
Thanks! that makes sense, and yes I can tell the rg59 isn't very flexible in short runs.
Do you think it will be a problem with using mica caps instead of ceramic? I'd just always read they're always a bit noisy if not a lot so I tend do avoid them like the plague.
~Phil
tUber Nerd!
Charlie Wilson
Phil, I have not actually listened to mica caps in that location but I know other forum members seem to prefer ceramic, as does Dumble. Also, small changes in value make a difference sound wise. At least to my ears. When I went from a Low plate classic to a high plate classic, I went from 270pf to 250pf and there was a difference. If you are ordering some other parts you may want to have a pair of 270pf ceramic discs waiting in the wings.
CW
pompeiisneaks
Site Admin
Charlie Wilson wrote: Mon Mar 12, 2018 11:34 pm Phil, I have not actually listened to mica caps in that location but I know other forum members seem to prefer ceramic, as does Dumble. Also, small changes in value make a difference sound wise. At least to my ears. When I went from a Low plate classic to a high plate classic, I went from 270pf to 250pf and there was a difference. If you are ordering some other parts you may want to have a pair of 270pf ceramic discs waiting in the wings.
CW
I think I'll plan on that, thanks. I may even have some that came out of the fender, I'll have to look.
~Phil
tUber Nerd!
Matt J
Post by Matt J »
Thanks for doing these videos Phil!
I've been out of amp building for a while due to school and work, but now I've finally got time to get back in to things and plan on doing a #124 build from a Trinity Kit. These videos have been great to follow! Thanks so much again for putting these out!
- Matt J.
pompeiisneaks
Site Admin
You're welcome :)
It also appears that I've only got a 250pF and a 500pF in the tone stacks of each channel, bummer, I'll have to get some
~Phil
tUber Nerd!
modman
Post by modman »
Charlie Wilson wrote: Mon Mar 12, 2018 3:33 amHello Phil, a couple things. Most the guys are using ceramic disc for the 270pf snubbers on the OD tube. They roll off some top end and smooth the overdrive.
:shock:
To my ears may well mean 'in my imagination'
Old ceramics have 20% tolerance, the 250pF may wel be 200pF or 300pF
The advantage of mica's is they are have lower tolerance, that's all.
