wire v2b #94
jelle
Re: wire v2b #94
Post by jelle »
Try clipping your probe to those....
Jelle
www.welagen.com
dorrisant
Re: wire v2b #94
Post by dorrisant »
jelle wrote:Try clipping your probe to those...
So... Maybe not so much of a voltage test point... maybe looking at a waveform. Cool to put that into perspective.
Re: wire v2b #94
I'm not buying it. You could see the waveform at the coax eyelet or the top of the Ratio pot. A loop could have been soldered into that eyelet more easily if desired. Is it a bare wire, or covered with white insulation? I think it's a remnant of some earlier tone shaping network.
JazzGuitarGimp
Re: wire v2b #94
Post by JazzGuitarGimp »
If HAD is reading this, I'd bet he is rather amused... :lol:
drew
Re: wire v2b #94
Post by drew »
67plexi
Re: wire v2b #94
Post by 67plexi »
My guess is that ratio resistor to the ratio pot had a jumper at one time
to see what value resistor worked best, resistor range 100k to 180k
and just spaced out cutting off that wire. Hard to see through the blue goop
but looks like #183 has that same uncut wire.
jelle
Re: wire v2b #94
Post by jelle »
Don't bother, Martin is not buying it. :lol:
