New amp build
Re: New amp build
http://bmamps.com/Schematics/dumble/dumblenotes.pdf
this is what I'm basing my build off of, for now. I remember I cannot recall his name, but he is a user on this site. This were taken out of a real amp, IRC
Re: New amp build
I've got some more tweaking to do but my pre amp voltages are (97notes)
V1A
199/1.95
(206/1.788)
V1B
212/1.735
(209.6/1.716)
V2A
227/2.09
(227.5/2.03)
V2B
236/1.96
(229/2.03)
V3
1=319 (317)
2=36 (36.6)
3=57 (60.9)
6=302 (303)
7=36 (39.
8=57 (60.9)
V4-V7
3=460(465)
4=454(457)
5= -42 (-40.7)
6=458(465)
dropping string is 3.3k 12k 10k
B+
1=461(465)
2=458(458)
3=433(433)
4=368(361)
5=332(323)
V1A
199/1.95
(206/1.788)
V1B
212/1.735
(209.6/1.716)
V2A
227/2.09
(227.5/2.03)
V2B
236/1.96
(229/2.03)
V3
1=319 (317)
2=36 (36.6)
3=57 (60.9)
6=302 (303)
7=36 (39.
8=57 (60.9)
V4-V7
3=460(465)
4=454(457)
5= -42 (-40.7)
6=458(465)
B+
1=461(465)
2=458(458)
3=433(433)
4=368(361)
5=332(323)
Re: New amp build
You might try upping the value on the first dropping resistor (3.3K)
Try 4.7K and recheck your voltages.
Re: New amp build
ive got some new tubes coming in, should be today, and i'll recheck the voltages then. Just courius, why up the resistor for the phase inverter, the voltages are pretty much spot on with whats listed.
Re: New amp build
That resistor will change all the voltages since it is first.
Re: New amp build
well I tried the 220/150/180/120 and got it sounding the best I could, but swapped to 220/150 on both v1 and v2. Man what a difference made the amp come alive. V3 is around 300v v2 at 210 and v1 at 200. I'm thinking of swapping from the low gain od entrance to the normal 220k 100k trimmer. what are you guys belifes on the difference between the two?
Re: New amp build
Yeah I have the high plates on V1 and V2 as well.
Hopefully you changed the cathode resistors too.
I think your voltages are pretty close.
Try different tubes and measure voltages, there can be a difference between tubes.
Re: New amp build
Finished the amp. Thank you to Taylor from Amplified Nation for the awesome tolex work on the cab
dcribbs1412
Re: New amp build
Congrats splgeo
sweet looking build
D
sweet looking build
D
Re: New amp build
Took it on the local tour of guitar shops, and had nothing but positive reviews
amplifiednation
Re: New amp build
Thanks to youamplifiednation wrote:Looks great!!
