More 'life' to high plate cleans
norburybrook
Re: More 'life' to high plate cleans
Post by norburybrook »
thanks Martin, well I'd say there's plenty of bass on the clean side anyway so I wouldn't want any more. So are you saying leave the 5uF's as doubling them to 10 will add bass?
Marcus
p.s. I 've also realised there different mid pot values for the EQ on the #124, I'll swap that out tomorrow as well.
Marcus
In another thread I mentioned a mod that switches the bypass cap on V1a.
It consists of a .68uF and 5uF cap on a switch.
This helps with single coils and humbuckers.
You can also put the LNFB on V1b on a switch to see if you like it with or without.
Another tweak is to put a switch on the Presence pot (full CCW to off) so I can turn off the global NFB.
It makes a louder output and is much more raw sounding.
I use this sometimes when playing real low volume.
The rest of the cathodes have 5uF caps on them.
I fought too much bass as well with my amp.
I also lowered the PI coupling caps to .05uF.
Charlie Wilson
Post by Charlie Wilson »
Marcus, the 10uf bypass caps also adds more gain in the bass and mids. I had 10uf(V1 only) on my low plate classic and switched them out for 5uf. I prefer the 5uf. The sound on the clean is a little more relaxed sounding and Fender like to my ears. You lose a little gain and fullness in the OD but I still prefer a leaner sound there also. I think most the guys prefer the 10uf.
CW
Last edited by Charlie Wilson on Sat Oct 31, 2015 8:27 pm, edited 1 time in total.
norburybrook wrote:thanks Martin, well I'd say there's plenty of bass on the clean side anyway so I wouldn't want any more. So are you saying leave the 5uF's as doubling them to 10 will add bass?
Marcus
Marcus
Partial bypass of the cathode resistor makes a roughly 6dB high-pass shelf. You can ball-park where the middle of the bass roll-off will be by using the 1/(2 Pi RC) formula where R is Rk and C is Ck. For 5uF and 1k5 that's 21Hz, but it will be 1-2dB down an octave higher than that at 42Hz. You can see that doubling the value of the cap will move it down by a factor of two, or one octave. It'd be easy to test by tacking another 5uF across the existing one. Worth a try.
ToneMerc
Post by ToneMerc »
martin manning wrote:Has anybody tried a hybrid low-high-plate configuration? Marcus if you are going to convert your 102 to low-plate you could change V1 first and see how that sounds.
I have a build what I called a Mo-plate, 100k/150k in both classic and skyliner configs At first tried 10uf on both v1 and v2 and in both configs I found the OD to be too muddy, so usually I put a 4 or 5uf on v2.
TM
norburybrook
I'm going to swap the bass and middle pots to #124 spec tomorrow, what can I expect from that? bass is moving to 250k, losing the cap and changing the resistor to 1.8k and middle to 100k pot.
Marcus
Charlie Wilson
Marcus, I think you are going off of the #124 as a low plate classic with the values you mentioned. Might as well try the .047 mid cap also. You are going to get less bass and mid range.
CW
norburybrook
Charlie Wilson wrote:Marcus, I think you are going off of the #124 as a low plate classic with the values you mentioned. Might as well try the .047 mid cap also. You are going to get less bass and mid range.
CW
cool, I think less bass and mid range will definitely make the clean sound more fender like.
Marcus
Is it a 25uF that qualifies a fully biased cathode?
I think that takes it down to 4Hz. :D
aflynt
Post by aflynt »
FWIW, I tried upping the cathode bypass caps and the lowplate-clean/highplate-od and preferred lowplate across the board with 4.7uF bypass caps. I thought upping the v1a or b bypass caps made the clean sound more like it did highplate. I basically tried a bunch of this stuff with alligator clips last winter before I settled on my current values. I've had the best luck trying things in place and listening like that.
-Aaron
Charlie Wilson
Aaron, I remember that you liked the 10uf on the clean side for the low plate classic. Did you go back to the 4.7uf? I found that by going back to the 5uf on the clean my strat sounded nicer and the OD was less harsh and buzzy.
CW
aflynt
Post by aflynt »
Charlie Wilson wrote:Aaron, I remember that you liked the 10uf on the clean side for the low plate classic. Did you go back to the 4.7uf? I found that by going back to the 5uf on the clean my strat sounded nicer and the OD was less harsh and buzzy.
CW
I wound up at 8uF on v1a/b on my Low Plate Classic. It's still kind of bassy, though especially with deep engaged. My main amps are Lowplate Skyliners that I kept at 4u7. I've kept the other amp as a LPC because it's so versatile. That comes at the expense of being a bit more difficult to dial-in, though.
-Aaron
Charlie Wilson
Wow 8uf. Cool, sounds like your are as picky as I am. Have you tried reducing the V1b coupler to .02 or so. I noticed Dumble did that with the Carlos Rios amp(SRV) and the Borderline. It really limits the effect of the bass control but it does reduce the boomy bass. I have a .02 in mine and I may go up just a little to .03. I also have a 330pf treble cap and I may reduce that to 300pf or 270pf so the high e doesn't jump out quite as much. I found if you go too low your lose the high end punch in the OD.
CW
aflynt
Post by aflynt »
Charlie Wilson wrote:Wow 8uf. Cool, sounds like your are as picky as I am. Have you tried reducing the V1b coupler to .02 or so. I noticed Dumble did that with the Carlos Rios amp(SRV) and the Borderline. It really limits the effect of the bass control but it does reduce the boomy bass. I have a .02 in mine and I may go up just a little to .03. I also have a 330pf treble cap and I may reduce that to 300pf or 270pf so the high e doesn't jump out quite as much. I found if you go too low your lose the high end punch in the OD.
CW
Never tried anything but .05uF in the v2b coupler spot. I'll give that a shot sometime. Thanks!
-Aaron
Guy77
Post by Guy77 »
JD0x0 wrote:I've got a 50W high plate, non-HRM that is lacking a bit on the cleans, single coils and buckers. Sounds a little too 'flat' dark and a bit too much compression. I like the somewhat 'singing' violin like quality, but the cleans dont sound '3D' and lively enough, especially with more mids dialed in (which I like for the OD)
Had a new production tung sol in V1 Plate voltages were roughly 10V low, swapped it out for a brand new one, and the plates went back up to about 190V. Sounded better, but still lacking. bright switch helps a bit, but causes ear fatigue and can get a bit harsh, so I often flip it back off within a few minutes
What's the best course of action to liven the cleans up? Should I add the NFB back to V1? I'm considering just dropping the plates to 180K/150K because I'd like some more dynamics from the clean channel, too. I dont think it needs to go all the way down to 100k, though. Thoughts or suggestions? Should I attack this one triode at a time? I attached an image of what I believe to be a fairly accurate representation of the preamp in my amp.
My 50 watt 124 high plate had the same issues. I tried many different values for V1 and V2 (100k to 220K) there was always a sacrifice with the Clean and OD channel. In the end I placed everything to stock 124 high plate values and placed the B+ rail on a 3 way switch with diodes and heat sinks and each positions changes the B+ by 20v. I found that when I ran the B+ at 430v cleans and OD were to my liking.
Cheers
Guy
