Is 33k the "standard" value for V1a for 100k plate
Max
Re: Is 33k the "standard" value for V1a for 100k plate
Post by Max »
Charlie Wilson wrote: I guess my inquiry was specifically about 100k plate load amps ...
I remember having seen this value (22k grid stopper) in original 100k plate load ODS amps with a "classic" tone stack and a "standard" OD circuit (trigger entrance, ratio pot, snubbers).
Max
stretch2011
Post by stretch2011 »
Just a thought here,
What if you used a 50K trim pot as the grid stopper to V1a?
That way you can dial in to what you like best.
ic-racer
Post by ic-racer »
My Super Twin conversion had two input jacks. Rather than a FET the input, the jacks go to either 22k or 33k grid stoppers on V1. That way I have a choice for which sounds best with each guitar.
