martin manning wrote:Thanks for posting those, CW. Do you know the serial number?
Yes Martin it is #189. I had this amp on my bench a few years ago and I just recently was looking at my photos and realized after staring at the resistor values in the PI that it is a 50W Bluesmaster.
CW
been mixing in the studio today but still managed a few hours on the amp.
Coming along, although it's been such a while since the last one I've forgotten all the little things I should have remembered and have made some of the same mistakes again painted myself into a corner with a few earth's etc.
couldn't find an elegant way to fit 5 cables into one eyelet on the power board so have had to attach two from the top....not pretty but seems mechanically sound.
Marcus
Eliminating the R/J switch is pretty straightforward; see marked-up T. Albany layout below. For the relays, I believe your PAB relay board will work with the connections moved appropriately, but the OD relay board would need some modification. Maybe you can find some "universal" boards?
where is the V1b coupler? I can't work out where to attach the wire from the 3rd leg of the master volume pot. Is there a schematic for the bluemaster?
Marcus
well......I've finished wiring it all up............forgot what a lot of work goes into these amps.
now the tricky bit. I'm always very apprehensive about the first power up . It takes so long to get to this stage it would be great if for once everything just worked!
now, I don't have the correct 3amp fuse ( I ordered the wrong size) can I use the 2 amp from my 102 for testing?
and, can someone quickly remind me of the testing procedure, I have my light bulb limiter ready.
if anyone can spot anything blaringly wrong now's the time to let me know.
cheers
marcus
