jcsifu wrote:
Maybe I will try an on/on/on switch for 3 options. I did that on my mid boost switch, (although an extra cap is needed for this application). Martin hashed out the design, though he refuses to take full credit for it...modesty.
I may go back and do the same thing for the mid-cap selection; although, it is hard to find a good place to locate the extra cap. Need to redesign the main component board to add some extra eyelets...
Thank-You (and Martin) for the mid-boost option; will eventually add that too!
Yup. Problem with options is the placement sometimes. I hope you find room to do this option, seems like it might work well for you.
Jam-mil Just found your thread/build today while looking up build information on a ODS preamp circuit. Looks nice. Do you have any sound clips?
Has the final schematic changed any? I've settled on the schematic on this thread but I'm only building the preamp.
I don't know that another Dumble build needs it's own thread but if the consensus is yes I'll start a separate build thread. I'm sure I'll need some assistance near the end as it is...
