going to build a bluesmaster. Any reason to do 100w ?
ODwan
Re: going to build a bluesmaster. Any reason to do 100w ?
Post by ODwan »
I use this as staking tool,
A bitholder with a 1,5mm hexagonal bit in a drill press.
norburybrook
Post by norburybrook »
Very clever :)
I've ordered one of those cheap Ebay craft eyelets kit's. Should be fine for a small HRM board.
Now back to parts ordering. I realise most off the extras I bought for my 102 are actually of no use for a Bluesmaster as they're all different values.
Marcus
norburybrook wrote:
M Fowler wrote:http://www.ebay.com/sch/sis.html?_nkw=7 ... 0576167785
Or make swedge tool for eyelets from old punch or bolt ground to taper fit the eyelet.
Brilliant, thanks Mark , I wasn't searching the right places.
Thanks again guys,
Love this forum :D
Marcus
Your welcome.
I use tools from Watts audio but I make a lot of boards and knew you did not want to make investments if you were not going to produce a bunch of boards.
ODwan wrote:I use this as staking tool,
Brilliant!
I took an old center punch and ground the tip a bit flatter, but has a point.
Drill board, push in eyelets, tape over eyelets so they can't fall out, and swage the backside of the eyelets.
I use another punch or have even used a very small ball peen hammer to flatten the backside.
Sometimes I put the punch in my drill press and use it to flare the eyelets.
I think I'll see if I have a screwdriver tip similar to yours, that looks more better. :D
rogb
Post by rogb »
If you are only going to make a few holes, no need to bother with a load of fancy stuff. Drill it, fill it turn it over and tap it - job done!
norburybrook
Roger,
you need to change your Avatar :D
Marcus
rogb
Post by rogb »
norburybrook wrote:Roger,
Marcus
Really? I hate to see her go, I'm just bad at that stuff. I even have letters from girlfriends from 30 years ago :D :oops:
