Another SSS - 4x6550 This Time
Re: Another SSS - 4x6550 This Time
Oh, I didn't notice the FET gain knob... I guess that was standard issue on some SSS.
amplifiednation
Post by amplifiednation »
Looks great Mike! That cab came out perfect!!! I just had to post mine too.
Amplified Nation
www.amplifiednation.com
@ampnation
mhartman
Post by mhartman »
Thanks guys. I didn't take a good gut shot before putting it in the cab, but here's a quick iphone snap that I took.
[IMG:1024:461]http://i276.photobucket.com/albums/kk12/mikejhartman/HartmanSSS150W_zpsd3532d55.jpg[/img]
Aaron
Post by Aaron »
I've seen this layout in black and white :D
It was asked in Taylors thread too, what is the reason behind the coiled cathode wires? Is this based on the original #005/HPD?
Aaron
Some nice wiring and layout in that chassis. Lot of room helps too. :)
mhartman
Post by mhartman »
Aaron wrote:I've seen this layout in black and white :D
Aaron
Hey Aaron,
Thanks. I believe that the coiled wires are merely functional. The cathodes (two of the coiled wires) need to be routed from one side of the tube to the others and up and away from the tube itself. I straight wire tends to move around easily, but the coiled wire tends to stay put. A thick, solid wire likely would serve the same purpose. As far as I know, the coiled wire was based on the original. I don't believe, however, that there are any secret marshmallows or crystal lattices involved with those wires. :wink:
