Post-OD 3-tube reverb schematic
Re: Post-OD 3-tube reverb schematic
More pictures:
Wow, very nice build!
Aaron
Aaron
Lovely build! Looks great and sound clips are expected!
As far as I remember, you arrein Europe, right? Where did you get the faceplates done?
Niki
Niki
Very nice! Do you have a schematic/layout to share?
Aaron, Synchu, mhartman, Thanks!
Niki, I'm not from EU, I am from Russia
. Faceplates - laser engraving on 2-layer plastic. E.g.
http://www.rowmark.com/laser/Lasermark/lasermark.asp
Look for the own local manufacturers of POS-materials.
mhartman, yes I have, but hand-drawing only
. I certainly drawn schematic.
i comcur, very nice.
TM
TM
Very nice job!
ToneMerc, jelle, many thanks!
Schematic (sorry for big size - small unreadable), may contain errors!
Very nice. Thank you!
This is AWESOME!!!!! Thank you!!!
Eric
1949 Zenith, Zenith Toggle Recoil, Zenith 55 & 440
Very nice build. Thanks for the schematic.
The schem does not include the Overdrive circuitry.
Jelle,jelle wrote:The schem does not include the Overdrive circuitry.
I noticed the same thing but all 6 9 pins are accounted for on the schematic and the panel has no OD control.
I don't understand, a POST OD reverb but no OD? Am I missing something?
Eric
dreric, CHIP, jelle, many thanks!
. It's a clean-crunch amp, no OD section.
. Raw, meaty crunch. I.e. post-OD reverb quite justified IMO.
Yes it isThe schem does not include the Overdrive circuitry.
Maybe You forgot about the Boost mode? Boost ON, Deep ON, Gain on 14-15 o'clock, Master to taste - amp growls at the Marshall territoryI don't understand, a POST OD reverb but no OD? Am I missing something?
OK I understand now.EaNot wrote:dreric, CHIP, jelle, many thanks!
Yes it isThe schem does not include the Overdrive circuitry.. It's a clean-crunch amp, no OD section.
Maybe You forgot about the Boost mode? Boost ON, Deep ON, Gain on 14-15 o'clock, Master to taste - amp growls at the Marshall territoryI don't understand, a POST OD reverb but no OD? Am I missing something?. Raw, meaty crunch. I.e. post-OD reverb quite justified IMO.
Thanks for working through the kinks in ODSR #60. The info I got was lacking in the reverb area.
Thinking I need to build this amp!
Eric
