Christopher Cross' other Dumbleland 300SL
Max
Re: Christopher Cross' other Dumbleland 300SL
Post by Max »
talbany wrote:What makes the basic topology of this amp different than Steel String Singer Ser # 002
AFAIR (right now and without a lot of research):
different filter circuit
different reverb circuit
different PI > driver circuit
Concerning input and tone stack I'm not completely sure right now.
Max
jelle
Post by jelle »
I am loving it! :lol:
Max
Post by Max »
jelle wrote:I am loving it!
Thanks for this valuable info!
Max
talbany
Post by talbany »
Thanks Max
So at this point just wondering how much different? and would it (for me) be different in a good way..
BTW.. In class AB2 that amp is pushing closer to 400w..SICK!!!
I am loving it!
Jelle
What about it are you loving?..:D
All The Best!
Max
Post by Max »
talbany wrote:So at this point just wondering how much different?
Do you remember what Brandon posted concerning the more general differences between the circuits of the different "generations" of SSSs and concerning the differences between his "EJ-version" of his HPD and his "SRV-version" of his HPD?
If so:
AFAIR the general topology of the preamp of this 300SL is more similar to the preamp of what Brandon called the "later" 150W SSSs, than to what Brandon called the "early" SSSs (like #002 e. g.).
And - if I don't mix up everything right now - the general structure of the PI>driver stage of this 300SL is more similar to the PI>driver stage of the SRV(Dumbleland)-version of the HPD (or 150W SSS,) than to the EJ-version of the HPD (or 150W SSS).
Does this make any sense for you?
Max
jelle
Post by jelle »
talbany wrote: Jelle
All The Best!
The cryptic nature of the description given by Max. I do not mind, in fact, I understand why. It is just amusing me. Never mind me...
BTW, I see two tall tube sockets: if I were to venture a guess, I would say that these are two paralel 12BH7 cathode follower drivers to maintain sufficient current supply into those 6550s.
Also, that row of preamp tubes at the front panel side, is that two or three tubes? I think that one on the left is a silver cap can. Anyone?
jelle
Post by jelle »
Max
Post by Max »
jelle wrote:BTW, I see two tall tube sockets: if I were to venture a guess, I would say that these are two paralel 12BH7 cathode follower drivers to maintain sufficient current supply into those 6550s.
Perhaps you can draw some conclusions concerning these pictures by looking at the attached data sheet of a DL 300SL and comparing it with the data sheet of a SSS 150W (posted above in a previous post) and comparing both with your own ("by Welagen") version of a 150W SSS?
BTW: AFAIR what Brandon posted concerning this topic, the structure of the PI>driver circuit of a Dumbleland Special 150W and the "SRV-version" of a SSS 150W is different from at least some PI>driver circuits of at least some SSS 100W and 150W.
Max
jelle
Post by jelle »
Max,
I do not build one version of the SSS. Not sure what to compare to in this respect.
But, I do see your point regarding this Dumble. Thanks for the data sheet! Much appreciated as I lost my copy.
Jelle
Max
Post by Max »
jelle wrote:I do not build one version of the SSS. Not sure what to compare to in this respect.
My recommendation: to all your versions.
Max
jelle
Post by jelle »
Still, I do not see the point of comparing the SSS circuitry to the Dumbleland circuitry. It is different by design approach, as you know.
The Dumbleland is more geared towards clean headroom with less compression, and fuller bandwidth than the SSS.
And based on the data sheet, if this Dumbleland shown here has the same tube compliment, it will have the typical Dumbleland circuitry.
67plexi
Post by 67plexi »
Does any one know what serial number this SSS amp is.
Steve.
jelle
Post by jelle »
Good question, and to add: is that the one that never got delivered to SRV?
talbany
Post by talbany »
Max
Somewhere I have the info Brandon mentions but if memory serves the main differences being the DL being a 12BH7/7025 combo and the SSS being (predominantly)7025/7025..AFAIK the circuits would be very similar and are interchangeable with balance and re-bias so this should go under tube compliment correct?..You are correct they do change the sound and feel!
IMO there are probably several ways to source grid current and drive the grids..Pick your tube and they all yield basically the same result..Class AB2 (it's not like a reverb or tone stack circuit)
Also Dumble used more feedback loops in the earlier designs and of coarse ran his 6550's at around 500V vs 450 in the 6L version..Is this what you are referring too?
I guess I am looking at it in a more broader aspect..
Does this make any sense?
Thanks again
talbany
Post by talbany »
Well we kinda figured that being it's double/triple/current the power of an SSS and twice the iron. :)
Tube compliment!
Can't tell but if that's the case then tube compliment would be
Input
TS recovery
Filter recovery
Reverb recovery
Reverb Driver
PI
Driver
Correct?
