..The two "Major differences (single amp/Cab) being..The change in attack, versus the softer diffuse attack. Also the reproduce able feedback phenomenon.(Feeding back on certain frequency's) ie..Fundamental,4th, etc..Due to (reversed) negative feedback coupling,with the amp CRANKED!!
BTW.. The Express and Liverpool Trainwreck designs are "out of phase with the input" ..I have never seen Ken order a directive to change his speaker phasing..I believed he thought it was a part of the amps character!!..(Maybe that's why I've never been a big fan of TW amps
)..Blackface AB series combos.with reverb tanks has 2 channels that are out of phase (Reverb being out of phase w/input) with each other...
If we look at Robbens rig and how he sets it up,
http://www.youtube.com/watch?v=jzVq9JsBLsI
In this type stereo setup he needs to pay attention to phasing issues...So it makes sense for him to use a phase reversed cable to be in phase with his Super when he runs them together and in Stereo!!!..Here is why..
Since the Amp and Lator have an odd number of gain stages (out of phase with the input) and he runs his Super in the Reverb side (again odd number of gain stages) the Dumble would be out of phase with the Super (The super being in phase) coming out of his TC unit.. So if he wanted to run them both in phase (to get full Stereo effect)) with each other the logical thing would be to reverse the Dumble or use the Normal channel in the Super.....There it is...Interesting huh!!
Here is a list of a few pedals that will reverse your phase..Sometimes reversing phase is a part of the pedals job to give you that sound..(especially with compressors or boosters!!)....If we did pickups it might be even longer!!
boosts/overdrives/distortions/pre-amps:
Analogman KOT (each channel inverts independently)
Bad Bob Booster
Badger Badgerplex Vintage Pre (The Badgerplex Plural does NOT invert)
Boss DS-1
Boss OD-1
Catalinbread Super Chili Picoso
Cmatmods Super Signa Drive (each channel inverts independently)
Colorsound Overdriver/Power Boost (and clones of)
Danelectro Daddy-O Overdrive
Devi Ever Dark Boost
Devi Ever Karaoke Party
Electra Distortion
Electro Harmonix LPB
Fuchs Plush Pure Gain
Fulltone Fat Boost1 (FatB2 and FatB3 do NOT invert)
Henretta Engineering Choad Blaster
Ibanez SML Super Metal
Kingsley Jester Overdrive/Boost (each channel inverts independently)
Legendary Tones (pre-Keeley) Time Machine Boost: Vintage channel inverts when engaged regardless of '66 or '73 setting. (Modern channel does NOT invert)
Lizard Legs Flying Dragon Boost
Lovepedal Amp Eleven (each channel inverts independently)
Lovepedal COT
Lovepedal Les Lius
Marshall Bluesbreaker OD
Menatone Dirty Blonde (6 knob knob version)
Menatone Fish Factory (each channel inverts independently)
Menatone Foxy Brown (4 knob jacks on top battery on side version)
Manatone Howie (6 knob version)
Menatone Red Snapper (4 knob red box, jacks on top version)
Menatone Shut Up And Drive
MI Audio Boost n Buff v1 and v2 (always inverted. inverts engaged AND bypassed)
MI Audio Tube Zone
OceanFX Pearl Drive
Seymour Duncan Twin Tube Classic (channel 1 inverted. channel 2 flips signal back to non-inverted when engaged)
Skreddy Screw Driver
Soulsonicfx Hunny Bunny OD
Telenordia Treble Boost
Xotic BB plus (each channel inverts independently)
Xotic EP Booster
Zvex Super Hard On (and clones of)
ANY single transistor boost....
(general):
ANYTHING that has 1,3 (or any other odd number) inverting gain stage(s).....for example: Spencer Subzombie fuzz
compressors:
MXR Dynacomp
Okko Coca Comp
all Ross compressors,clones and variants invert: some examples.....
Analogman Bi-comp (only one channel inverts) (Ross side of the Bi-Comp inverts. Orange Squeezer side does NOT invert)
Analogman CompRossor
BYOC 5 knob compressor
GoudieFX Compressor
Keeley Compressor
Retro-Sonic Compressor
Wampler Ego Compressor (compression signal inverts. clean blend does NOT invert)
delays:
Biyang AD-10 (only dry signal inverted, repeats are non-inverted)
Blackbox/Ooh La La Quicksilver
Danelectro Dan Echo (always inverted. inverts engaged AND bypassed)
Danelectro Fab Echo (always inverted. inverts engaged AND bypassed)
DLS Echo-Tap
DMB Lunar Echo
Electro Harmonix Deluxe Memory Man
Empress Super Delay / Vintage Modified
Ibanez AD-80 (always inverted. inverts engaged AND bypassed)
Lovepedal Echo Baby
Seymour Duncan Deja Vu (when true bypass: inverts when engaged / when buffered bypass: always inverted. inverts engaged AND bypassed)
SIB Blue Echodrive
TC Electronic Nova Delay
fuzz pedals:
Blackout Effectors Musket Fuzz (from Kyle @ blackout: "5 inverting gain stages, which results in flipped polarity")
Bluebird Fuzz
Colorsound Tonebender (and clones of)
Electronix MessDrive Hybrid
Fender Blender
Gretsch Controfuzz
Maestro Brassmaster / Malekko B:Assmaster
MI Audio Pollyanna
Mosrite Fuzz Rite (and clones of)
Skreddy Lunar Module and Dlx
Soulsonicfx Shizzle fuzz
Spencer Mixmuff
Spencer Subzombie (stage #1 and stage #3 invert)
Spencer Suprazombie
Zvex Fuzz Factory
(general):
octave up fuzz's
modulation pedals:
chorus:
MXR Micro Chorus
TC Electronics Chorus
flangers:
MXR Micro Flanger
Ross Flanger (ac powered)
phasers:
MXR Phase 90 (original)
Red Witch Moon Phase
tremolos:
Danelectro Cool Cat Tremolo
Danelectro Tuna Melt Tremolo (always inverted. inverts engaged AND bypassed)
Effectrode Delta Trem Tremolo
vibe pedals:
Effectrode Tube Vibe
vibrato pedals:
Behringer UV300: inverts in "latch" and "unlatch" mode / does NOT invert in "bypass" mode (inverts in some modes but not in others)
multi fx:
Digitech RP-155 (always inverted. inverts engaged AND bypassed)
noise reduction:
Behringer NR300
PEDALS THAT INVERT PURPOSEFULLY(to correct out of phase pedals etc.)
- Barge Concepts VB-jr
- Badger Schism
- GigRig Humdinger
- GigRig Wet Box
- One Control Mesquite Blender
