Great job finding that missed ground. I feel like most of us just need to talk it out, once your done explaining online (or in person) its usually 10x easier to troubleshoot
Take some clips! Why do you suggest this preamp iver the mayer?
Hybrid Build Issue *Fixed*
amplifiednation
Re: Hybrid Build Issue *Fixed*
Amplified Nation
www.amplifiednation.com
@ampnation
@ampnation
Definately, once I drew up the schem and cross checked everything one at a time I've realized that layouts are only good for that. Wiring is still best done from a schem.amplifiednation wrote:Great job finding that missed ground. I feel like most of us just need to talk it out, once your done explaining online (or in person) its usually 10x easier to troubleshoot
Mostly cause this pre is taken from the SSS and the Mayer has an ODS style pre. I think the feedback from V1B plate to V1A cathode/100R resistor plays a major roll.amplifiednation wrote:Why do suggest this preamp iver the Mayer?
Aaron
A quick update. Had the 4.7M ohm resistor on the overdrive output and felt there was a slight drop in volume compared to the clean, so changed it to a 3.3M ohm. A much better balance between channels now.
Got to try it out tonight at a local jam, first thing I noticed is a lot bloody heavier to carry with the Marshall iron!!!! Soundwise, worth the pinched nerve!
Will record some clips on the weekend.
Aaron
Aaron
Recorded a couple of little clips.
Settings were:- vol 6, treble 5, mid 4, bass 3, drive 3, trimmer 2, master 4, pesence 4.
Siganal flow:- sm57 - AML1073 - Hairball Audio 1176 - protools.
Guitar is, stock 72 strat with dynaverb straight in the front. Clean sound was neck/middle pickups. OD sound was neck then switched to middle.
Apologies for the playing
https://soundcloud.com/sleepwalk-studio ... -overdrive
https://soundcloud.com/sleepwalk-studio ... an-riviera
Aaron
Aaron
