The standard is only one tap is wired to both jacks in parallel. The main has the shorting safety feature. The other tap is not used.martin manning wrote:No. I haven't actually done one like this, but I don't see any down-side. If you plug two speakers in the shorting jumper isn't connected to anything, and you get a miss-match like plugging two speakers into the main and extension jacks on a Fender (a bit different depending on whether the speakers match the high or low impedance, or both).doveman wrote:Have you tried this? As I read it, you use either jack to engage either tap. What happens if someone unfamiliar with amp plugs something into both jacks?Do I understand correctly that the recommended wiring on the Accomplice Jr. is just connecting one jack? If so, then this would be better, IMO. You would have two jacks, one for 6L6 and one for 6V6, both being 8 (or 4) ohms, and you preserve the shorting safety feature.doveman wrote:This would be awesome in my Allen Accomplice Jr. It has a dual tap OT (6L6 8 ohm & 6V6 16 ohm) or (6L6 4 ohm & 6V6 8 ohm). Same as the Accomplice but no room for a switch since it's a smaller chassis. But this would allow swapping tubes and rebiasing. But you could have the proper match with the OT too. In Allen's design, he chooses the first tap because it matches 6L6 at 8 ohms and tolerates 16 ohms with the 6V6. Wondering if the 6V6 set up might get a bit more volume with the matching tap? I'm just starting my build.
My preference: it's a 1x12 combo. So with this option, I would replace tubes - change the speaker jack - rebias. If I ever do use multiple speakers all my cabs are easily set to run off one plug. So, I'd have the most flexibility and proper tap. I would probably rarely change but this would be cool if it worked the way I think it does.
