NFB on multi-tap OT
pdf64
Re: NFB on multi-tap OT
Post by pdf64 »
Roe wrote: Tue Aug 21, 2018 10:34 am 100k NFB @ 4 ohms= 141k @ 8 ohms = 200k at 16 ohms.
I prefer a 27k resistor in series with a 220k pot at @ 16ohms
I think those values are more relevant to 5F6A based circuits, rather than 2 channel BF amps, whose NFB circuit resistances are much lower :?
Roe
Post by Roe »
pdf64 wrote: Thu Aug 23, 2018 12:10 pm
yes, but it is the ratio that matters. the BF uses a 100R, not the 5k pots
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
pdf64
Post by pdf64 »
Roe wrote: Thu Aug 23, 2018 12:37 pm
Absolutely, but I suspect that such a leap in circuit analysis may be lost on @espinete 's current level of understanding :wink:
Roe
Post by Roe »
For a blackface ab763 circuit (with a 100R NFB resistor in the phase inverter instead of the 5k presence pot), you can try a 470R resistor (instead of the 27k) and a 5k pot for variable NFB (instead of the 220k pot)
4x12" w/H75s
