Low Plate Skyliner, High Voltage....In Progress
ic-racer
Re: Low Plate Skyliner, High Voltage....In Progress
Post by ic-racer »
sepulchre wrote:I see. Clever!
So some, or most of the wiring is between the boards then, right? I hadn't noticed that before.
Yes. The utility of a backing board is questionable because it would be unlikely for a lead to stick all the way through and short out on the chassis (unlike the boards that are not mounted on standoffs). But the pictures of most Dumble amps show a backing board behind the main board.
He used stiffer stuff. The Wilsonart stuff is thinner and mine came with a distinct curve to it.
ToneMerc
Post by ToneMerc »
[quote="sepulchre"]Formica? Two pieces glued? (sorry, I'm new to this process)[/quote
Yes, formica
TM
ToneMerc
Post by ToneMerc »
The ODS build bug is back.
TM
Colossal
Post by Colossal »
Looks really nice TM, well done.
ToneMerc
Post by ToneMerc »
Colossal wrote:Looks really nice TM, well done.
Dave, no that's IC's excellent 90's HRM build, not my build. I was trying not to start a new thread, maybe I can get Tom to cull this thread some.
Mike
dobbhill
Post by dobbhill »
TM: I need an octet of EL34/KT77/6CA7 (HiFi rig with VTL Compact 100's) that can handle 525vdc B+
Do you like the 6CA7 from JJ?
"high plate, non-hrm, skyliner with JJ big bottle 6CA7's"
D
There are no stupid questions, just stupid people.......
Colossal
Post by Colossal »
Mike
Haha, ok Mike, my mistake. That's what I get for skimming the thread.
bluesfendermanblues
Post by bluesfendermanblues »
dobbhill wrote:TM: I need an octet of EL34/KT77/6CA7 (HiFi rig with VTL Compact 100's) that can handle 525vdc B+
D
I have a quartet of "Winged C" el34 in a #183 clone with vintage Partridge transformers, that were sourced from an old 70s Laney amp.
B+ is 560VDC.
So far the have delivered 2 year of relentless performance.
Be carefull with the bias. I run it at 18mv, which is on the hotter side.
talbany
Post by talbany »
Mike
A Friendly reminder.
you may want to ohm that board out if you have not already.. That stuff can get conductive.. :shock:
ToneMerc
Post by ToneMerc »
talbany wrote:Mike
Thanks Tony, yeah I've used that formica board before and it tests and works fine. However, I installed parts on it earlier and after staring at it for a few moments, I asked myself why am I really doing this when I have a more suited board ready to go. Thus, I stripped the formica board and populated this one.
TM
I haven't found enough of those resistors to populate a board. :)
ToneMerc
Post by ToneMerc »
M Fowler wrote:I haven't found enough of those resistors to populate a board. :)
I've been slack on scrounging vintage parts in the last year or so because I haven't built a full blown ODS in like a year and half. When I pulled parts for this build over a year ago I had intended to be different and use all CDE brown drops. I decided a few days ago to stick with what know and use the 70-90s vintage 6PS caps. So when culling parts earlier I found I only have one .1 left and low on a few other values,so maybe I will be turning overs rocks soon looking for vintage 6PS caps again. This build will have 30% taper CTS AUD pots,a couple which are actually NOS.
It takes a lot of work to find vintage parts. You can search everyday for 12 months and come up short, then take a break for 6 months and halfheartedly search and trip over what you have been looking for all along.
TM
talbany
Post by talbany »
Mike
I have found the difference between the old 70's PS series and the newer ones to be not that much different (after break in and oriented shield to PS) and not worth the time and added expense to go scrounging for them..YMMV of coarse!..BTW.. Good move on the board I think.. :D
Good Luck with the build!
mlp-mx6
Post by mlp-mx6 »
Tony, did you mean 'not worth the time'? I'm confused.
Me: Just one more...
ToneMerc
Post by ToneMerc »
mlp-mx6 wrote:Tony, did you mean 'not worth the time'? I'm confused.
I think he was saying that if you adopt the methods of breaking in the new caps and orientating their outer foil, then it's not worth the effort of chasing the vintage ones.
TM
