not all TR PTs are the same so voltages can vary
regarding the 4 ohms to 8 ohms mismatch: (small) part of the Dumble-sound imo
SSS Power Transformer 100W Design
PaisleyTube
Re: SSS Power Transformer 100W Design
Chris
Love, peace & loudness!
classictone has a nice new twin PT with low and high voltage taps. It delivers around 470v on the high voltage taps and delivers 450mA
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
4x12" w/H75s
groovtubin
Couldn`t agree MORE!ER wrote:Stiffening up the secondary reflection is a common method for tweaking an amps tone (especially 6l6s). Kimock runs 16 ohm cabinets on an 8 ohm tap, and for what it's worth before his sss amps came along Stevie Rays vibroverbs had a 2 ohm super reverb OPT hooked up to an 8 ohm EVM 15L.
Typically this will give you less power and bring the midrange forward (attenuation at the frequency extremes). Another important factor is the effect this has on the feedback/presence values, you may not be hearing what HAD intended without the proper-improper load.
Sakuma-san say's it like this;
'It is only after much cut-and-try that I find my best matching point for audio. The tube manual is like a telephone book. It gives perfect numbers. It is useful to make it possible to speak with a girl- but we cannot see her beautiful face from the mere telephone number."
-E
Respectfully, jim@Omegaamps.com
