New build complete: CE Silverface 6V6 HRM
ToneMerc
Re: New build complete: CE Silverface 6V6 HRM
Post by ToneMerc »
The OT has been mounted and heater string almost completed. FYI, this PS board was setup for the first cap node after the standby switch (only 6 eyelets), but I set it up as it's normally done with the standby switch after the first cap bank.
As with the previous build using this style of board, I mounted an insulated 3 eyelet terminal board under the main power board which terminates the standby switch out, choke in and OT B+.
TM
steve_p
Post by steve_p »
TM,
Do you have a picture of the extra terminal board you added?
Do you feel it makes wiring easier or cleaner?
Thanks,
Steve
ToneMerc
Post by ToneMerc »
steve_p wrote:TM,
Thanks,
Steve
Sorry Steve I didn't take a pic. It's just a .500 x 3.00" board with 3 eyelets which are jumped together and each board side is insulated with a backer board.
I purchased these PS boards from a member here a few years ago. Normally D style precision PS boards have 8 eyelet terminations facing the tubes, this particular board only has 6 terminations. I just needed a work around to keep the same functionality as a typical PS board. Thus, no advantage of sort.
TM
steve_p
Post by steve_p »
Ahh, cool.
The precision PS that I have is from jborders, so I already have the 8 eyelets.
Build looks great so far.
Steve
ToneMerc
Post by ToneMerc »
Now the hard part is finally over. Well I'm on the fence about the HRM daughter board, eventhough I purchased the items the other day to etch a board. I think I'm going with my original idea of the integral PA/HRM board setup.
TM
amplifiednation
Post by amplifiednation »
Ahhh and the fun part begins!! Great work TM. I need to hear clips of these 4x6v6...or build one myself!!
Amplified Nation
www.amplifiednation.com
@ampnation
talbany
Post by talbany »
amplifiednation wrote:Ahhh and the fun part begins!! Great work TM. I need to hear clips of these 4x6v6...or build one myself!!
Taylor
Here is one I built.. Marshall MM OPT..4XJJ 6V's...Gain CRANKED!! (not the best recording)
Enjoy
Mike amp looks great so far...Rock it!!
dcribbs1412
Post by dcribbs1412 »
Looking good TM
So are you going to use the HRM board you have on hand?
Hoping to see pics for future reference.
Tony is that Derringer live?...sounds like a loud rockin good time.
talbany
Post by talbany »
Yep!!..I wish I had a better sounding live clip..He can still throw down..
ToneMerc
Post by ToneMerc »
dcribbs1412 wrote:Looking good TM
Nope, going back to my original intergral HRM layout. While the daughter board is nice and modular, it's just another PITA cog to work around for mounting to the main board. I don't really the resolution of those tiny 10mm trimmers, so I have bounty out on 25K & 250K Piher carbon 15mm(3 leg mount) vertical adjust trimmers.
TM
ToneMerc
Post by ToneMerc »
Finally got the main board punched.
TM
steve_p
Post by steve_p »
Do you have a drawing of your main board with the HRM included?
DXF or other cad file would be killer so I could just drop it on to the milling machine, but anything would be good too...
Thanks,
Steve
ToneMerc
Post by ToneMerc »
Been about 3 weeks, time to finish this one up. Need to tack in 4 strands of coax, mount the PT and then the grid stoppers.
TM
amplifiednation
Looks great TM! I'm itching for a 4x6v now...
Tony that clip rocks...some serious gain on that solo!!
Amplified Nation
@ampnation
dreric
Post by dreric »
TM
As usual, the build looks great. I'm always impressed with your part selections. Seems like your are straying from the 6PS convention, care to fill us in on your cap choices and the thoughts behind them?
Is that a switch on the back of the mid pot! For?
Also, I'd second the request for a copy of the main board layout. I have a custom rj chassis that I had made up a 6V6 HRM and the board would move the project along nicely.
Thanks for your consideration.
Eric
