All of the parts arrived, mostly from
www.newoldsounds.com (they've got good prices, good selection, but have trouble shipping things quickly for the last couple weeks). I started by replacing the stock 16uf filter caps with fresh ones @475v. They all tested like 20uf caps, but I'm not upset. Maybe the Fender gods are.
I made a couple of recordings of some unfocused noodling guitar with the "before" mods and then plugged in the soldering iron and took them all out. I also completely removed the components for the vibrato circuit (just the vibrato circuit, the actual channel is still there without the tremolo functionality). The only component remaining is the tube socket.
Attached is my shamefully messy redraw of Weber's Fender AB763 layout from his amp kits sales site (
https://taweber.powweb.com/store/kits_60a.htm#6A20H). I used Ted's layout rather than Fenders because it's easier to read. Other than some higher-voltage electrolytics, it seems to be dead-on to the Fender AB763 layout.
Also attached are a few before and during pictures of the mod in progress. The "before" pictures point out the cascading switch that puts signal from the normal channel after the volume control into the grid of the vibrato channel before the tone stack. The signal is also then routed through a master volume control with push/pull switch to add/remove the undistorted normal channel signal direct to the phase inverter tube.
[IMG:800:533]
http://i315.photobucket.com/albums/ll45 ... G_3445.jpg[/img]
[IMG:800:533]
http://i315.photobucket.com/albums/ll45 ... G_3446.jpg[/img]
[IMG:800:533]
http://i315.photobucket.com/albums/ll45 ... G_3448.jpg[/img]
Below is an attempt at a "presence switch". It's got a 330pf cap coupled with a 470ohm resistor (half of the resistance of the stock neg. feedback ground resistor). It definitely adds presence and not much mud. Just a SPDT on/on switch.
[IMG:800:533]
http://i315.photobucket.com/albums/ll45 ... G_3449.jpg[/img]
[IMG:800:533]
http://i315.photobucket.com/albums/ll45 ... G_3456.jpg[/img]
[IMG:800:533]
http://i315.photobucket.com/albums/ll45 ... G_3457.jpg[/img]
[IMG:800:641]
http://i315.photobucket.com/albums/ll45 ... ODMod2.jpg[/img]
Can you see the #124 ODS overdrive channel? It's beginning to take shape using the space and leads vacated by the tremolo stuff.
Ignore most of the purple and yellow scribblings: I was trying to think through a lead dress and switch design that temporarily fell through because the DPDT/1M audio pot/switch I got wouldn't work for any of the available chassis holes.
I have some questions about the B+ voltage calculations. I don't know what to expect when the circuit is finished and I plug it in, but my guess is that I'll have a lot more voltage at the plates than #124 had (200v). The #124 schematic calls for 100k plate resistors. Since I'm getting the B+ from the first filter cap and that's also the cap feeding the power tubes, is there a way to calculate the size of the resistors I'll need to achieve the correct voltage? I'm hesitant to build the circuit and turn it on without knowing whether I'll get 220v or 470v and if the new 12ax7 will survive it or not.
I'll also work on putting the "before" sound clips somewhere. I'm not a guitarist, so don't expect the playing to sound any particular way.
Please pardon my photoshop skills. The layoud mod was done in a hurry but it is useful.
So, B+ management ideas? Anything else?
Thanks!
